Dell cedar amd mb goes in suspend mode suddenly
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    MB CODEELL CEDAR AMD MB 13283-1
    This mb came dead to me. There was corrosion around PU4501 which i've corrected and even replaced the ic with same part number(new). The laptop boots fine, goes to windows desktop but suddenly shuts down. There is no pattern of shutdown time. Sometimes it shuts off in 1-2 min, whereas on couple of times it runs for 40-50 mins. On restarting the laptop i find its resuming-so not shutdown in the perfect sense.
    Steps taken:
    01.Replaced PU4501(twice-both new)
    02.Replaced KBC Nuvoton 285
    03.Bios flashed.
    04.Sound,lan,card reader chip removed.
    There is no corrosion elsewhere, no liquid spill. I coul'nt locate the LID SW on this laptop anywhere. On screen panel, there is no magnet raising my suspicion of no lid sw on mb.
    I get 3.7V on PL4501(should be 3.3V) and 5.1V on PL4502.
    AMD mb-so no me region.
    I'm out of ideas. Any suggestions friends??
    • 22167
    Re: Dell cedar amd mb goes in suspend mode suddenly
    According to the schematic the lid switch is LIDSW1 ,goes to LID_CLOSE# - TOUCH_PANEL_INTR# - TP_RS
    • caspian
      • Oct 2015
      • 1591
      • Laptop
      I recommend that you install a complete Linux on this weird laptop. Linux is supposed to print some messages while shutting down. you can also test the laptop using Ultimate Boot CD.
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        I've the schematic and noted that but physically i couldnt find any lidsw on mb,usb extension,power switch.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Yeh,worth checking
          • piernov
            • Jan 2016
            • 4439
            • France
            Try to monitor voltage on pin 17 (LID_CLOSE#) of EC anyway.
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              it remains at 0V even when it goes in suspend mode.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                I tried clean install of windows 10 on this laptop. It went into suspend mode during setup(almost 80% windows loaded). Same thing happening with linux install.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  LID_CLOSE# should be high so that's probably the problem.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Yes, i do agree on that but i could'nt locate lidsw on this mb and kbc i've replaced(new). So really couldnt findout the reason behind it.
                    • dj_ricoh
                      • 2073
                      • uk
                      Are you sure it's not temperature heat protection?
                      Can you feel the heat coming out?
                      • piernov
                        • Jan 2016
                        • 4439
                        • France
                        Well there should be a hall sensor somewhere.
                        If you really cannot find it you can at least cleanly cut the trace going to the EC pin 17 and jump 3D3V_S5 to the EC pin 17. That should confirm if it's the problem.
                          • 22167
                          The datasheet for the hall switch https://cdn.badcaps-static.com/pdfs/...effc8f10ac.pdf
                          Its a SNT-4A 4 pin IC, so that should make it easier to find... .Is there a magnet embedded in the bezel .
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            Yes, sure its not related to temp. Fan always spins and the onboard cpu is not that hot.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              I think you are looking at wrong schematic.As per dell cedar beema schematic on page 64, hall sensor is 3 PIn.
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Finally a big thanks to piernov. Yes there is a hallsensor located between hdmi and lan port but its not there-seems someone who worked earlier has removed it. There is no magnet in the panel either-so that make me confused.
                                O volts on all pins of LID sw. resistance on pin3 of lidsw was very low. Finally checked C6402 and it was leaky though it appears fresh. Removed C6402 but still 0V on all pins of lidsw though resistance is good now.
                                As a last resort, as per piernov's advice i cut track of pin17 of kbc and applied 3D3V_S5 directly on pin17. All is well now and its working for more then 2 hours on video.
                                Thank you all who bothered to answer/help.
                                  • 22167
                                  Yes ,i had 4-5 schematics open at the time comparing TOUCH_PANEL_INTR# . The hall sensor datasheet still has some good info .Glad you fixed it
                                  • Bowline
                                    by Bowline
                                    06-11-2025, 10:13 AM
                                  • Akhlz001
                                    by Akhlz001
                                    09-20-2025, 07:15 PM
                                  • master3112
                                    by master3112
                                    07-29-2025, 01:55 PM
                                    Dell Thunderbolt Firmware
                                    by SMDFlea
                                    Dell thunderbolt firmware, extracted from dell firmware update exe. Padded to 1MB.
                                    Some models have a choice of 2 different firmwares, it depends on the dell SKU.
                                    The SKU is in brackets (****)
                                    EDIT: NVM65...
                                    01-26-2025, 06:22 AM
                                  • dell_sadness
                                    Dell Latitude 3440 - Service tag ending in 0001 - Locked!
                                    by dell_sadness
                                    BIOS password locked Dell Latitude 3440 (Service tag B4HNJX3)
                                    Have extracted the BIN and want to know how to rebuild a clean BIOS
                                    I have come across the 8F8C patcher but not sure if that would work in my case as the service tag ends in 0001.
                                    I tried it and although the log states it patched several mentions of 8F8C in the BIN, I haven't flashed it yet in case such a patch wouldn't work.
                                    Have also tried to extract a clean BIN file from Dell's .exe BIOS updates using 'Dell PFS Extractor', but not confidently; Ended up with a 25MB file instead of the same 32MB...
                                    11-12-2025, 02:54 PM
