Macbook Pro 2010 13" A1278 (EMC 2351) boot loop
  • Pgratis
    • Jun 2020
    • 10
    • Portugal
    I have one MBP 13" that started to refuse to boot.
    Two months ago the WiFi chip stopped working but that was solved by putting a Wifi USB dongle (the Aliexpress Wifi Module is on it's way since early April).
    This weekend the MBP didn't started. When pressing the power button I saw some activity (the led was on and I got the DVD head sound, but black screen and no chime).
    After some time I've replaced the current DIMM's (1 original 2GB PC3-8500 + 1 PC3 10600) that have worked without issues since 2012, with new DIMM's.
    Then the weird stuff started to happen.
    When using only PC3-8500 DIMM's (from another Mac that is working great) there is no boot.
    When using only new PC3-10600 DIMM the MBP boots, I get the white screen with the Apple logo and the progress bar goes up to 60% and then it starts to loop reboot.
    I've opened the MBP, made visual inspection and the only thing I see is there are some dry solder joints on 2 inductors (L7400 and L7401) that power the CPU, but I guess it's not related to this problem.
    My wild guess is there must be some capacitor which is malfunctioning and driving the DIMM voltage to a level that the PC3-8500 don't “like”, but I cannot find where to look for.
    Any suggestion is more than welcome.
    Thanks.
    BR,
    PMA
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Macbook Pro 2010 13" A1278 (EMC 2351) boot loop
    You MUST use PC3-8500 on this machine. Not sure why it wouldn't work with it though, clean the RAM slots and try another RAM stick. (try each slot alternatively, the one closest to keyboard can fail)
    Note that the cheap RAM sticks coming from China are often misadvertised with wrong frequency, don't trust them…
    • Pgratis
      • Jun 2020
      • 10
      • Portugal
      I know I need PC3-8500 for it to work (I've been using one original DIMM to trick the chipset to lower the frequency for quite a few years now).
      I've tried 3 different PC3-8500 modules from a working Mac but this motherboard refuses to boot with all of them.
      I've reset the SMC (with keyboard and by removing the battery) to see if the chipset would start to collaborate, but this MBP now only "likes" PC3-10600 DIMM's.
      I'm adding some photos of the motherboard.
      Thanks for the prompt reply.
      BR,
      PMA
      P.S. - The DIMM's are only from reputable sources (Micron/Samsung)
      • piernov
        • Jan 2016
        • 4439
        • France
        Inductors look ok.
        Did you try PRAM reset as well?
        Motherboard is pretty dusty so always good to clean that. Note that if you are in a high humidity environment, dust can catch the humidity and disturb signal lines. Remove the speaker as well.
        Dust can also get into the RAM slot and cause weird problems.
        • Pgratis
          • Jun 2020
          • 10
          • Portugal
          Originally posted by piernov
          Inductors look ok.
          I can't reset PRAM with the "official" DIMM's because I never get the white boot screen, but I've done it several times with the higher speed DIMM's, so I believe that part is don.
          I've cleaned the board out of dust but I'm having doubts how to clean the RAM slot contacts.
          Thanks.
          BR,
          PMA
          • Pgratis
            • Jun 2020
            • 10
            • Portugal
            I've cleaned the board, replace the thermal grease and remounted the system but still the same behaviour.
            I've tried to use the original DIMM on both slots but there is no boot.
            With the 1333MHz DIMM's the boot goes up to 50-60% and then starts looping.
            Any ideas?
            Thanks.
            BR,
            PMA
              • 21969
              What voltage do you get on PPSPD_S0_MEM_A
              • Pgratis
                • Jun 2020
                • 10
                • Portugal
                On the board view that would be "PP3V3_S0", right?
                I've measured 3.25VDC on a resistor that was connected to that line.
                I've also measured the DIMM VDD "PP1V5R1V35_S3" and it measures 1.48VDC.
                BR,
                PMA
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  The behaviour with non-PC3-8500 RAM is expected. I genuinely have no idea what's causing the issue with PC3-8500, maybe a dying MCP but still weird that it POSTs with non-PC3-8500.
                  • Pgratis
                    • Jun 2020
                    • 10
                    • Portugal
                    I've tried several techniques to identify what is happening with this logic board but I'm on a dead end.
                    With the correct DDR3 modules:
                    - I've measured the power buses and all seems to be ok.
                    - I've heated up the logic board (using a hot air gun) to see if some capacitor would start working, but no fun either.
                    The computer keeps POST works ok with the higher speed DDR3 modules.
                    Any ideas?
                    Thanks.
                    BR,
                    PMA
                    • Pgratis
                      • Jun 2020
                      • 10
                      • Portugal
                      I've replaced the DIMM with new 1066MHz version.
                      I was able to reboot the MBP once and run the ASD EFI without any errors but I have to stopped it because the computing was getting very hot and the fan was spinning in normal speed which could damage the logic board.
                      Now when I try to start it I see the fan spinning hear the DVD drive seek but get the black screen and no chime.
                      Taking out the 1066MHZ DIMM and putting the 1333MHz DIMM alone in either slot I can have the logo and the OS starts to load.
                      Mixing both DIMM's I get the same black screen and no chime.
                      I have PPVCORE_S0_CPU with 1.1V and PP1V5R1V35 with 1.48V with either DIMM's.
                      Any help is appreciated.
                      Thanks.
                      BR,
                      PMA
                      [EDIT] P.S. - I've noticed that, even with the black screen, the MCP and CPU are getting very hot.
                      Last edited by Pgratis; 06-19-2020, 08:51 AM. Reason: Update with MCP and CPU heating.
                      • Pgratis
                        • Jun 2020
                        • 10
                        • Portugal
                        Here follows my update.
                        After a huge fight with the Logic Board, where I've reflowed the MCP and the CPU with a hot air gun the symptoms kept the same.
                        One thing I've remembered while in desperation was to correlate this issue with the Wifi board malfunction and Bingo!!!
                        After disconnecting the Wifi/camera cable from the logic board the MBP booted normally and started working without any major issues.
                        Then I've unplugged the Wifi board and the MBP kept booting, so it ruled out being a problem on the camera.
                        I've runned the ASD with success (only complained about the HDD - which I've replaced with a SSD), so no problems.
                        Now I'm waiting for the replacement wifi board to close this subject.
                        Actually I will need to downgrade the OS from High Sierra to Sierra. The poor Core 2 Duo is being pushed to the limit with the High Sierra.
                        Thank you all for your tips and assistance.
                        Hope my message can also help someone.
                        BR,
                        PMA
                        • Takeatry
                          Yet another Samsung QLED Boot Loop
                          by Takeatry
                          Samsung QLED QN50Q — purchased 2022 started experiencing a delay in the picture coming on in the morning less than 2 years later. Did not know the term boot loop at that time. As the loop delay ran into a few minutes did all the recommended troubleshooting, soft and hard reset, changing cables and outlet locations, no help. As the delay increased contacted Samsung tech group and allow them remote access the tv. Tech was moving too fast to see exactly what he was doing but this ultimately it was also no help. Lived with the delay until it stretched out over 6 hours. Pulled of off the back cover...
                          10-04-2024, 02:57 PM
                        • NConstantinou
                          Macbook pro 13" mid 2010 a1278
                          by NConstantinou
                          Daer all
                          i need bios but i am not 100% sure about model
                          i beleive is a1278. No labels on board.
                          I am attaching bios file.
                          Laptop does not power on and i need bios file
                          thanks...
                          11-16-2022, 09:19 AM
                        • Abdulrahman
                          Apple Macbook Pro A1278 13″ (Late 2010)
                          by Abdulrahman
                          Test OK...
                          11-23-2022, 09:06 AM
                        • blaster_
                          Samsung UE49MU6105K - boot loop, horizontal lines
                          by blaster_
                          Less than a year out of warranty, samsung UE49MU6105K craps out, they've got this designed obsolescence down to an exact science of self destruct when out of warranty...
                          Screen started to show horizontal lines and ghosted image at the bottom, then turned off by itself. Did software update, to no avail of the line problem, and got a boot loop after some minutes of watching TV. This boot loop will turn on the backlights for some seconds the sound comes on, the image will turn dark very fast and then it reboots again. Pressing power button will not put it on standby. Disconnecting...
                          06-22-2022, 05:19 PM
                        • Stefano Crivellari
                          Lenovo Legion 5 (15ITH6H) kind of boot loop but not sure
                          by Stefano Crivellari
                          Hi, I wonder if anyone can help me fix my Lenovo Legion 5 (15ITH6H) laptop. Basically, after a windows update the computer would not boot anymore. When powering on the laptop the screen has no backlight and nothing would show up, using an external monitor did not help. However, the laptop would still spin up the fans and turn on the keyboard backlight. The keyboard backlight intensity function key would work and the power button led and the charging led are also working. I've tried every possible combination of key press and power button hold down time but did not change anything. At this point...
                          01-14-2025, 03:49 PM
