Macbook pro 820-2936-b problem with heating some parts
  • zvonko72
    • Jul 2016
    • 20
    • Serbia
    Hello
    When my macbook was turned on, I noticed that it was heating up terribly u9480 and the temperature was a bit lower at u9390.
    What is the cause of this, where I could check.
    My macbook works normally I just have a problem with this temperature
    Macbook pro mid 2012
    820-2936 b
  • dellxps15
    • Feb 2014
    • 1596
    • italy
    Re: Macbook pro problem with heating some parts
    they are both related to displayport. check if its all clear in that connector -zone
    • zvonko72
      • Jul 2016
      • 20
      • Serbia
      Thanks for the reply.
      I took out the motherboard, removed all the connectors and cleaned with alcohol. I didn't see any problem with the displayport. Maybe I needed to check something else, voltage or some resistance or maybe...
      • p_d
        • Sep 2020
        • AU
        u9480 must have a short on its output , according to Ti's docs it will current limit to ~1a.
        if it gets to hot it will shut itself down.
        with the power off what resistance is there between pin 1 of u9480 and ground
        • zvonko72
          • Jul 2016
          • 20
          • Serbia
          I measured u9480-19,6KΩ
          Whether this is correct ?
          • zvonko72
            • Jul 2016
            • 20
            • Serbia
            I'm coming back to this motherboard after a long time.
            In the meantime I replaced the U9480 q9425 and U9410 but I still have a very hot U9480.
            It can help ?
            • Cemal Odabasioglu
              MacBook Pro A1707 Motherboard Diagnostic Help – CD3215 heating and Fluctuating Rails
              by Cemal Odabasioglu
              I'm currently diagnosing a MacBook Pro A1707 motherboard that does not power on. I've gathered some data but am stuck and need expert advice.
              Note that i'm a beginner in electronics and i'm trying to learn while trying to repair this macbook that my work gave me. I'm really curious and love understanding how thing works and i already learned so much.
              Only one usb c port is taking 20v and have 12.5v on PPBUS_G3H. when trying other ports, 2 are not going to 20v and one is going to 20v but the CD3215 is getting really hot.
              Observations...
              01-14-2025, 03:54 PM
            • envym
              by envym
              Hi everyone!
              06-27-2025, 08:54 AM
            • Flasman90
              Macbook Pro DFU Restore Issues
              by Flasman90
              I have a 2020 Macbook Pro A2289 and after many attempts managed to get it into DFU mode, using my older 2017 A1706 Macbook Pro (Running Ventura 13.7.8). However, when attempting 'Restore', it fails at step 4 of 4, showing the following error:
              - "The operation couldn’t be completed. (AMRestoreErrorDomain error -1 - Failed to handle message type StatusMsg (Generic error)) [AMRestoreErrorDomain – 0xA (10)]
              - "The system cannot be restored on this device. Failed to create new state machine for restore [com.apple.MobileDevice.MobileRestore - 0xFB1 (4017)]
              08-30-2025, 10:27 AM
            • boosti45
              Macbook pro logic board replacement parts quesion
              by boosti45
              i have a 2020 macbook pro 13" A2251 with 820-09149 logic board so i found an issue with chip labeled U6903 according to schem. boardview using flexBV software, so i removed it from the board and the issue im having is that the chip says "07A08FI ELC180​" on top of it but when searching for a replacement chip, i can find tons of identical looking chips that also have "ELC180" printed on them but the first set of digits is never the same so im trying to find out if i need this exact chip with these same numbers as mine and if not which ones are compatible as a replacement?...
              08-21-2024, 05:23 AM
            • tobeend
              Bypass mdm macbook m2 ventura
              by tobeend
              1. RESET MACOS WITH IPSW
              a. Power off MacBook, press and hold the power button to enter Recovery
              b. Open Disk Utility, remove Macintosh HD
              c. Reboot, connect to the network to Activate Mac.
              d. Plug the C cord in the first port of the MacBook into the other Mac, then power off the MacBook
              d. Hold down the Control (L) + Option (L) + Shift (R) + Power key combination for 10 seconds
              e. Release the other keys, but keep holding the Power key for another 10 seconds
              f. MacBook is returned to DFU, open Apple Configurator 2 on the other Mac, right-click...
              05-26-2023, 07:18 AM
