Lenovo 320 80XH
  • zmeutz
    • Nov 2016
    • 84
    • Romania
    Lenovo 320 80XH
    I have a problem with Lenovo 320 board 80XH, it starts only if I reset bios(pull out battery and bios battery) but after I shut it down it doesn't start again only if I reset it ...
    anyone had this problem?
    I have write bios ic data and ec data from forum, but same situation ...
    thanks!
  • stingerchamp
    • Sep 2020
    • 425
    • Pakistan
    Re: Lenovo 320 80XH
    If you pull out bios battery only and start with both main battery and charger will it start?
    If not then problem is with main battery or adapter in general
    If you start with adapter only and it does it means problem with main battery
    Bios battery voltage must be 3 or greater for laptop to start in normal way, without it laptop will boot at 3rd attempt after restart
    Confirm problem with main battery or not by start only with adapter plugin
    • zmeutz
      • Nov 2016
      • 84
      • Romania
      Re: Lenovo 320 80XH
      ok, tested
      AC connected - bios disconnected / doesn't start
      main battery connected - bios disconnected / doesn't start
      main battery disconnected / ac connected / bios connected - doesn't start
      main battery connected / ac disconnected / bios disconnected - doesn't start
      bios battery voltage / 3.1v
      • stingerchamp
        • Sep 2020
        • 425
        • Pakistan
        Re: Lenovo 320 80XH
        At which state it works?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Re: Lenovo 320 80XH
          What do you mean by bios disconnected?? Which kbc it uses?? Check RTc section like RTC_RST#/SRTC_RST#. Look for jumper marked on mb "cmos1" or "me1"
          • lucaszmn
            by lucaszmn
            Problem:
            Initial Findings:
            • I concluded that the
            08-12-2025, 03:01 PM
          • Wahaz
            by Wahaz
            10-30-2023, 08:42 PM
          • gestalt.exe
            Lenovo Legion Y540 – Need help repairing BIOS after bad downgrade
            by gestalt.exe
            My Lenovo Legion Y540 (i7-9750H, RTX 2060) bricked after I downgraded from BHCN44WW to BHCN21WW.
            Laptop stopped booting entirely.
            I used a CH341A programmer to dump the corrupted 16MB BIOS.
            i then attempted the following:
            1. Downloaded stock BIOS BHCN39WW from Lenovo
            2. Trimmed it to 16MB
            3. Extracted the BIOS region from the corrupted dump
            4. Extracted the BIOS region from the stock 39WW
            5. Replaced the corrupted BIOS region with the stock one (within hxd , opened the corrupted dump and replaced its region by the stock)
            6. Injected back my LDGB / DMI
            11-30-2025, 10:38 AM
          • grimacelord
            Lenovo Legion T5-26AMR5 Desktop - Corrupt BIOS
            by grimacelord
            Hello there.
            I am working on a Lenovo Legion T5-26AMR5 desktop that currently has a corrupt BIOS and I have been unsuccessful thus far in trying to fix it myself.
            History:
            1. This computer came to me initially with an error message that said "BiInitializeLibrary failed 0xc0000001" or "0135 fan error". It would always be one of the two errors. It should be noted that when it produced the fan error, there was no physical problem with the fans. They were all spinning just fine.
            I searched for this error online and discovered...
            03-15-2023, 03:29 PM
          • mkdj
            Lenovo IdeaPad 3 - Hard Disk not recognized in BIOS
            by mkdj
            Dear all,
            I have recently fixed a Lenovo IdeaPad 3 15 ALC6 that was not booting due to a BIOS issue. After flashing the BIOS, the laptop boots up, but hard disk is not recognized in BIOS. Is says "Hard Disk : Not Installed". I have tried with 2 different drives (one that I know is working on another laptop) but I get the same result. I do not know if disks were recognized before I got the laptop and fix it, but I don't see any reason why not. I can boot on USB though.
            Here the steps I have taken to fix the laptop:
            - downloaded latest BIOS from Lenovo Website...
            10-18-2025, 03:43 AM
