Laptop Fujitsu E744 broken power on/off connector
  • brnk
    • Dec 2020
    • 9
    • Croatia
    Is it possible to turn on laptop Fujitsu E744 with broken power on/off connector?
  • brnk
    • Dec 2020
    • 9
    • Croatia
    Re: Laptop Fujitsu E744 broken power on/off connector
    This is the area on the motherboard around the connector:
    This is the same area from the otherside of the motherboard:
    • stingerchamp
      • Sep 2020
      • 425
      • Pakistan
      Power on off connector ?
      You mean ribbon strip blue colour?
      • Askic
        • Sep 2018
        • 187
        • BIH
        It seems that connector has been ripped away from the board. This is clearly shown in picture nr. 1. What else is this ribbon cable used for?
        Somehow I doubt it is used only for power off/on button.
        Edit: I have just seen that there are some probably LED signalization together with Power ON/OFF through this ribbon. On your picture it is visible that some pads are very damaged but you may be lucky. Not sure about your knowledge but you can test if it is possible to startt by connecting cahreg and inspecting remaining available pads for 3.3V. Laptop is started by shorting this 3.3V to ground. So it may be possible to solder additional two wires from the power button to these pads. Tis would require a very skilled person with experience in motherboard soldering.
        • stingerchamp
          • Sep 2020
          • 425
          • Pakistan
          If daughter board become absent
          You can not close the lid or maybe safe in your case
          Are you ready to short pins every time?
          Better solder a push button or your choice
          • brnk
            • Dec 2020
            • 9
            • Croatia
            More pictures:
            • brnk
              • Dec 2020
              • 9
              • Croatia
              I want to solder a push button, but I need to find which pins to short.
              • Askic
                • Sep 2018
                • 187
                • BIH
                The best thing I would do is to use multimeter set to ohms to measure resistance between tracks while pressing power button.
                Like I said, power button works in such way to short 3.3 V to ground and that is a signal for startup chip to start all power supplies on the motherboard. Also, as you know, when keep power button pressed for about 10 sec that is so called emergency shutdown.
                So I would use this PCB board with power button and try to identify which tracks corresponds to power button. (100 kohm when PB open, around 0 when pressed) Then follow those tracks and see which pads on the motherboard they belong to. Install new two wires and solder between these two boards.
                This is what I would do. Luckily you have only three buttons, you can perform something similar to wificard button and eco mode, but I guess that is not that important.
                EDIT: please have a look at this video from about 12th minute and you‘ll see what I‘m talking about.
                  Fujitsu LIFEBOOK E744 Notebook E Specification for Upgrade or Repair
                  This specification for the Fujitsu LIFEBOOK E744 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the E744 boardview and E744 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for Fujitsu LIFEBOOK...
                  09-06-2024, 05:59 AM
                  09-06-2024, 05:27 AM
