Asus GL503V does not power on battery
  • lezsimply
    The Wanderer
    • 647
    • Philippines
    Hi guys, I've got an Asus GL503V that does not turn on when using battery but works perfectly using adapter.
    It came in with no power. I resolved the issue by replacing 2 mosfets PQ21, PQ22 and an mlcc 10uf 25v on +VIN_VCCGFX_CORE line.
    When I power up the laptop, BIOS detects battery and shows 100%. It's the same when booting up on windows, It shows 100% on taskbar. Despite that still can't turn on using battery.
    When adapter is inserted, PCN2 connector pins 1,2 and 3 shows random voltage between 2.6v to 4.6v constantly changing. When battery and adapter is inserted, I only get 0.20v on pins 1,2 and 3 of PCN2 connector.
    Can you guys give any idea as to where I should check next?
    I don't have schematic for this but I uploaded boardview. Hope someone checks. Thanks
  • lezsimply
    The Wanderer
    • 647
    • Philippines
    Re: Asus GL503V does not power on battery
    I still haven't found any solution to this. I replaced charging IC BQ24780s 3 times. I also replaced PQ82. All surrounding components on PU15 was also checked and found nothing faulty. I even replaced PQ26 and PQ27 just to make sure, but still battery wont charge and voltage on P_MBAT pins 1,2 and 3 is fluctuating. What else could I possibly miss??? I'm beginning to realize that I may not found a fix for this... Hope someone takes a glimpse. Thanks.
    PS laptop works perfectly fine, I just cant charge the battery.
    • piernov
      • Jan 2016
      • 4437
      • France
      Of course using known good battery?
      • lezsimply
        The Wanderer
        • 647
        • Philippines
        The battery is good, so I ruled it out from the start.
        • myth77
          • Feb 2017
          • 380
          • Croatia
          What hapends if you unplug the charger while laptop is working? (with battery attached)
          BAT+ voltage stable?
          PR505 and PR506 resistence ok?
          • lezsimply
            The Wanderer
            • 647
            • Philippines
            @myth77
            Laptop turns off immediately after removing charger with battery connected.
            At B+ I get random voltage between 5v to 8v. Its like ticking with 1 second interval. This happens without battery. If battery is attached I get 0v on B+
            PR505 and PR506 resistance is ok (220k ohm)
            I got 3.3v on CLK and DATA on PCN2 connector.
            I get 100% battery in Bios pls check image. Thanks
            • superhache
              • Nov 2018
              • 46
              • Argentina
              hi there, did you fix it? coz, i have the same problem here with a gu502du. pleas let me know, thanks
              • FrozenHaxor
                • Jun 2015
                • 260
                • Poland
                Did you try a known good different battery first? It's like 90% of issues.
                  • 21403
                  Its a different model to the one in this thread. Off-topic Start your own thread .
                  • luckydip
                    • Aug 2016
                    • 165
                    • uk
                    I've had 2 laptops in the GL series with the BQ24780s chip with battery issue. Changed the chip and tried two working batteries but couldn't get the battery charging issue sorted. Worked fine on charger.
                    • MICHAEL_2013
                      • Feb 2016
                      • 54
                      • Colombia
                      Hi, friend. were you able to solve the problem? I have the same computer with exactly the same fault. Thanks.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        Give us measurements of BQ24780S pins and we'll help you sort it out. Without any measurements, no one can help. Mentioning only symptoms dont help in technical resolution.
                        • razadom
                          • Apr 2015
                          • 105
                          • Madagascar
                          Hi man
                          Did you solved the problem or not
                          I have the solution if you always need
                          • usyusy
                            • Sep 2021
                            • 171
                            • Pakistan
                            Originally posted by razadom
                            Hi man
                            whats the solution bro.
                            • kalu
                              • Dec 2011
                              • 48
                              Hi man
                              I have 3 Asus GL with this problem, can you help?
                              • mon2
                                • 14488
                                @kalu - say what ?
                                What are the silk screen markings on your logic board ?
                                Logic board works with adapter but not with battery ?
                                Are the batteries good and charged or dead at this time ?
                                • kara
                                  • 9
                                  Hello. I had the same problem with a asus laptop, after disasembly the battery was not working. The solution was to put the battery back in, connect the charger, laptop asus starts by itself. After that i press the power button for 1 minute, laptop is power off and after 1 minute of presing the power buton, the laptop is starting and the battery is charging, and power on on battery.
                                  • mkdj
                                    by mkdj
                                    Mark and model: ASUS X571
                                    Tests already made:
                                    - I have removed...
                                    07-14-2025, 09:16 AM
                                  • Iherduleikgemz
                                    Asus FX505DY - Battery not charging - BQ24780S
                                    by Iherduleikgemz
                                    Hello everyone
                                    I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
                                    I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
                                    01-13-2025, 03:54 PM
                                  • cope
                                    Battery not charging in ASUS G532LWS Motherboard -> BQ24780S
                                    by cope
                                    I have been working on a no power issue with my personal ASUS gaming laptop. It went dead a few months ago.
                                    Some history:
                                    Since then, I've found a blown mosfet on the GPU line which I replaced. It started up without a battery, then when I added the battery back it wouldn't start up again.
                                    As a result, there were some blown components around the BQ chip. (The BQ chip itself - BQ24780S, the low side battery mosfet (shorted), and a resistor -> all replaced)
                                    Now, with a new battery the system will start up and run off...
                                    05-13-2024, 09:40 AM
                                  • dr.thodt
                                    Asus GA401Q only working from battery
                                    by dr.thodt
                                    I have an Asus GA401Q which only works from battery power. That suggests the board is mainly fine.
                                    The battery status is 255%, also with a brand new battery.
                                    The BQ24800 was replaced since it showed signs that it was part of the problem, but possibly the battery was flat at that moment.
                                    If I insert the 19V adapter in the DC jack and measure the current sense resistor's voltage it fluctuates between 0V and 19.5V and the keyboard backlight flashes (probably because the battery is almost flat. It does the same when I run the laptop from battery).
                                    There's a...
                                    12-20-2024, 08:23 AM
                                  • techfreak9356
                                    Vostro 3400 (LA-K033P) won't charge battery, everything else ok
                                    by techfreak9356
                                    09-14-2023, 11:10 PM
