HP Pavilion Laptop Motherboard Not Starting Up DA0R53MB6E1
  • venadillo
    • Mar 2015
    • 7
    • Colombia, south - america
    Re: HP Pavilion Laptop Motherboard Not Starting Up
    have same issue quanta r53 but my case no have 3.3v in pin 11 kbc only have 0v any help
    • venadillo
      • Mar 2015
      • 7
      hi friend have issue hp g6 quanta r53 no power , no have 5v 3.3v
      power button act, 3.3v , vreg5 5v vreg3 3.3v
      any help
      • mon2
        • 14662
        Re: HP Pavilion Laptop Motherboard Not Starting Up DA0R53MB6E1
        vreg5 5v vreg3 3.3v
        You HAVE these rails working on PU7 ?
        VREG5
        VREG3
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          @venadillo, gone thru your PM. We can help but for that you need to start a thread with useful information. You have given practically no information.
          So, you confirm VREG3/VREG5 is present but no voltage on coil. Is that correct??
          If yes,Check the following
          01.PU12 IC-Pin20/17/15/13
          02.PU8-Pin5 Voltage??
          AD_ID voltage??
          Post these measurements and then will follow the progress.
          Btw, No DC Jack Light glowing??
          • Crabolog
            • Apr 2022
            • 30
            • Ukraine
            Hi, have almost the same issue, hp pavilion g6, DA0R53MB6E0, with AC in, after click on pwr button, led blinking 3 times, no power on.
            Here are some measurements:
            vin 19.2
            vin on PU7 16 pin = 2.5v
            VREG5 = 0.008v
            VREG3 = 1.7v
            ENABLE = 0V
            POWERGOOD = 0V
            ENTRIP1 = 0.01V
            ENTRIP2 = 0V
            Additionally when AC in, I can feel with my finger that PU12 discharge IC is pretty hot.
            Could someone please advice on this, thanks
            • Sephir0th
              • Oct 2020
              • 1289
              Check the Resistance to GND of the Enables and the outputs (VREG3, VREG5, Phase1 and Phase2) around PU7. Maybe already something supsicious to measure there.
              FairRepair on YouTube
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                #27
                PU7, pin16-VIN-must be 19V. Are you measuring the pin correctly. the dot mark on the IC is pin1 and next pins in anti-clockwise fashion.
                • Crabolog
                  • Apr 2022
                  • 30
                  • Ukraine
                  #28
                  I've just double-checked:
                  PU7, pin16 - 2.5v
                  GND to:
                  VREG3 = 105 kOhm
                  VREG5 = 10 Ohm
                  PHASE1 = 10 kOhm
                  PHASE2 = 9.3 kOhm
                  ENABLE = infinite
                  Anything else I can check?
                  PQ50, PQ53 pins 5/6/7/8 = 19.7v, while schematic says there should be 5v.
                  PQ51, PQ52 = no voltage
                  PL24, PL25 = no voltage
                  pr245, white resistor = 2.9v
                  resistance to gnd:
                  PL24, rising from 10 to 12 kOhm
                  PL25, falling from 12 to 9.5 kOhm
                  PC74 = 10 Ohm
                  • Sephir0th
                    • Oct 2020
                    • 1289
                    PU7, pin16 - 2.5v
                    GND to:
                    VREG3 = 105 kOhm
                    VREG5 = 10 Ohm
                    PHASE1 = 10 kOhm
                    PHASE2 = 9.3 kOhm
                    ENABLE = infinite
                    resistance to gnd:
                    PC74 = 10 Ohm
                    We have Multiple or another fault present here. Check resistance to GND of Pin16, too
                    One fault might be there or a burned PR110
                    The thing with PQ50 and PQ53 is your wrong interpretation of the Drain designation and missing understanding of how a buck converter works.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #30
                      VREG5 is shorted but first need to fix VIN of PU7. No point troubleshooting PU7 unless VIN is fixed. PQ50/53-@sephiroth has already highlighted your misunderstanding-its correct at 19V. Do follow his suggestions and check resistance to GND on PR124-any pin. PR124 is located just after dc-in mosfets.
                      • Crabolog
                        • Apr 2022
                        • 30
                        • Ukraine
                        #31
                        PR 110 resistance is 0.460 kOhm
                        Resistance PU7 pin 16 to the ground is not stable, during the measure it fell from ~6 mOhm to 3 mOhm and keeps falling.
                        Same for PR124 - gnd, it falling from >10 mOhm to 3 mOhm and below, like if capasitor is loosing it's charge.
                        Anything else I can check? appreciate your answers
                        • Sephir0th
                          • Oct 2020
                          • 1289
                          PR10 is supposed to have 10Ohms internal resistance, so it has failed open. Likely caused by a bad PU7. For VREG5 you could inject 1V and see whether PU7 is getting hot or something else. Should be enough proof then to finally remove it afterwards.
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            #33
                            Yes, replace PR10 as suggested with rated value and then remove PU7 from the board(dont put power while PU7 is removed). Check resistance on VREG5 again after removing PU7.
                            • Crabolog
                              • Apr 2022
                              • 30
                              • Ukraine
                              #34
                              You guys mean PR110 ?
                              • Sephir0th
                                • Oct 2020
                                • 1289
                                Yes, PR110
                                • Crabolog
                                  • Apr 2022
                                  • 30
                                  • Ukraine
                                  #36
                                  Changed pr110 to 10 Ohm resistor and removed PU7
                                  Resistance to gnd:
                                  VREG5 = 0.86 megaohms
                                  VREG3 = 410 kOhms
                                  Anything else I should check or proceed with installing new PU7?
                                  • Sephir0th
                                    • Oct 2020
                                    • 1289
                                    I have nothing against to proceed with PU7. precautions made, Should be fine now.
                                    • Crabolog
                                      • Apr 2022
                                      • 30
                                      • Ukraine
                                      #38
                                      Still not starting.
                                      Vin on PU7 = 19.7v
                                      VREG3 = 3.3v
                                      VREG5 = 5.2v
                                      PWRGOOD = 0v
                                      PHASE1 = 0V
                                      PHASE2 = 0V
                                      ENTRIP1 = 0V
                                      ENTRIP2 = 0V
                                      ENABLE 0V
                                      LGATE1 = 0V
                                      LGATE2 = 0V
                                      UGATE1 = 0V
                                      UGATE2 = 0V
                                      BOOT1 = 4.5V
                                      BOOT2 = 4.5V
                                      PU12 is still getting hot, pin 15 ACIN on it has 0.005v, pr175 has 19.7v on one pin and 2.3v on another pin that is closer to PU12
                                      led is blinking 3 times and thats all. Please advice
                                      • Crabolog
                                        • Apr 2022
                                        • 30
                                        • Ukraine
                                        #39
                                        PU12 pins:
                                        20 VIN = 19.0V
                                        17 VOUT = 20.4V
                                        15 ACIN = 0.005V
                                        13 12VALW = 11.8
                                        PU8
                                        pin 5 ACPRES = 0.005v
                                        pin 6 ACDET 2.8V
                                        PR100 has 19.7v on one pin, and 0.08 on the other pin
                                        • mon2
                                          • 14662
                                          Check the voltage to ground of:
                                          Pu8
                                          Pin 20 - VCC
                                          Pin 16 - REGN
                                          Pin 4 - ACDRV
                                          Post each measurement.
                                            HP Pavilion Pavilion Laptop 14-dv2513sa Notebook 14 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Laptop 14-dv2513sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2513sa boardview and Pavilion Laptop 14-dv2513sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            09-07-2024, 05:50 AM
                                            HP Pavilion Pavilion Laptop 14-dv0631sa Notebook 14 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Laptop 14-dv0631sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0631sa boardview and Pavilion Laptop 14-dv0631sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            HP Pavilion Pavilion Laptop 14-dv2500sa Notebook 14 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Laptop 14-dv2500sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2500sa boardview and Pavilion Laptop 14-dv2500sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            HP Pavilion Pavilion Laptop 14-dv2501sa Notebook 14 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Laptop 14-dv2501sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv2501sa boardview and Pavilion Laptop 14-dv2501sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                            HP Pavilion Pavilion Laptop 14-dv0632sa Notebook 14 Specification for Upgrade or Repair
                                            This specification for the HP Pavilion Pavilion Laptop 14-dv0632sa Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Laptop 14-dv0632sa boardview and Pavilion Laptop 14-dv0632sa schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
