HP Gaming laptop 15-cx0812no no power on battery
  • RickRockerr
    • Dec 2021
    • Suomi
    Hi!
    My customer brought an HP gaming laptop with weird symptoms.
    When the laptop is plugged in to AC, charging light lights up, but when the laptop is turned on, all the lights shut down and light up again in few seconds. When the laptop finally turns on, there's no problems whatsoever and everything seems to work like normal except for the battery.
    Laptop shows that the battery is at 100%, but the laptop shuts down straight away when unplugged. HPs battery test says that everything seems fine.
    Battery pins 4,5 and 6 give voltages 3V, 2.76V and 2.76V
    I couldn't find any schematics for this board, but I assume that the intersil 88739A is the main power IC. 88739A gives the following voltages plugged to AC, no battery:
    1. 2.1V
    2. 2.7V
    3. 3.1V
    4. 3.1V
    13. 3V
    14. 0.1V
    15. 0.1V
    17. 0.8V
    18. 19.4V
    19. 5.3V
    20. 5.3V
    22. 0.1V
    27. 17V
    28. 11.8V
    29. 19.6V
    30. 24.7V
    AC and Battery:
    1. 2.1V
    2. 2.7V
    3. 3.1V
    4. 3.1V
    11. 1.9V
    16. 2.2V
    17. 0.8V
    20. 5.3V
    24. 4.9V
    27. 17V
    28. 11.8V
    29. 19.6V
    30. 24.6V
    31. 19.7V
    32. 19.7V
    Only battery plugged:
    3. 2.7V
    4. 2.7V
    I'm not very familiar with HP boards and would appreciate if someone could give a little help to get us to the right direction.
    Images of the board here
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: HP Gaming laptop 15-cx0812no no power on battery
    All the lights glows and shuts off in aloop for 2-3 times and then it works. right?? its 'coz of cmos reset as cmos cell is inside main backup battery. May be battery is faulty or any component on the output path from battery is shorted. Check which is the output pin on mb battery connector and see if the 10-12v from battery flows to the mb or not. Very likley a shorted cap/mosfet or battery itself.
    • serious_electron
      Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
      by serious_electron
      Hello Everyone!
      I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
      06-28-2025, 02:57 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • ahmarzo
      Acer TMX314-51 laptop battery problem
      by ahmarzo
      I have acer laptop tmx314-51 with part no 6050A3020501.
      The laptop is working fine on adapter and battery is also charging and when adapter is disconnected in on state the laptop gives backup on battery and gives good backup.
      But when laptop is powered on through battery only the laptop does not power on and there is 0 voltage on battery connector.
      I have not not tried another battery as it is not available locally could this be a battery problem.have checked discharging mosfet and there is no shorting to ground on any pin of battery connector.
      The schematic is not available...
      04-11-2025, 09:14 AM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
      NVDC charger configuration...
      11-05-2024, 03:28 PM
