First attempt on MB Troubleshooting (Beginner here
I bought this HP OMEN for parts with a faulty MB.
OMEN PN : 15-DC0997NF
Important points to notice before to start with troubleshooting : I got this unit without charger (specific 200W/10.3A for this model) and without peripheral components (RAM, WIFI, SSD, HDD).
I am currently using a 65W HP charger to check the MB. Want to know if I can recover this MB before investing in an expensive charger/RAM. And maybe that will become a problem in the next steps (If I recover power).
Symptoms :
Common issue : Plugged in, no power light no charge light.
19.5V pass the first Mosfets (but Noticed 25V on the MOSFET gates, normal ?)
3.3V is there (3.301), SR40B chipset warms up slightly when plugged (powered by 3.3V).
No 3.3V @ power button.
I get 5V on the Input connector, but it comes from a small regulator on the backside. I don't think the 5V rail is UP. 5V should be the Buck near the 3.3V ? but no volage measured in the area (No Voltage on the MOSFET gates).
One component detected very hot (I can't keep a finger on it) : 5 Pins S88P15, No info about this chip. (Find on the web this could be equivalent to G5243AT11U : Power distribution switch for USB line overload ?).
There is a short between pins 1 and 2 (OUT and GND) with <1Ohm to ground for both.
I think this could be the faulty component... or maybe the Capacitor between GND and OUT...
Pics :
So this is theorically what I would do :
Unsolder the component check if short still present (to determine if capacitor could be the cause) then if CAP is OK, try to short this remote switch (PINS 4-5 to 1) ==> This would remove Overload protection... until I find a replacement component.
Would like to get feedbacks before any action, as I also consider selling the laptop package (in the same state I bought it) for parts without touching it (I don't have Hot air soldering station). Thanks
Symptoms :
Pics :
