Dell 5502 0wnvyk intel 11th gen no power
    Hi guys
    With USB c plugged in 19v 0.02 amps only.
    Vsys is around 16v, 5v and 3v present on CPU regulator ic isl95869, pch supply ic rt6543a, mxic bios ic, and 3v on power switch. But on pressing power button there is no response. Also battery not charging, no voltage on battery.
    No 1.8v / 1.0v PCH rt6543 en is pulled 10ohm to gnd when there is pwr
    no CPU vcore
    Any ideas ?
    Re: Dell 5502 0wnvyk intel 11th gen no power
    Originally posted by ss45 View Post
    Hi guys
    no CPU vcore
    Any ideas ?
    what is board ID?
      This 0wnvyk
        NO POWER when checking resistance.
        Remove all power / NO battery -> meter in resistance mode (lowest scale).
        Now, proceed to check the resistance to ground with meter probe on PCH rt6543 en and other meter probe to GROUND.
        What is the reading ?
        Are there other markings on your logic board ? Unable to find any schematics for this model in my (paid) database of schematics / BV files.
        Can you post pics of the logic board to show all white silk screen markings or labels ?
          rt6543 en pin when no power at all above 25kohm
          Here are the pictures hope you can make sth out of it
            The enable pin is fine with such a high resistance. There is no short here.
            Repeat the same test on the cpu vcore rail using the lowest resistance scale on your meter.
            Post the measurement and scale used on your meter.
            Cpu rail is a low voltage and is expected to be a low resistance as well.
              -> no dispute here
              Vcore measurements 40ohns and 150ohms
                Anybody has schematic for isl 95869
                One of us cap is around 4 ohm to ground
                See attached
                  Review the attached, the datasheet may be similar to your device. Post your update.
                    First tnks for pointing that out but I had checked that datashet before I posted here
                    The capacitor is connected to the 5th pin of the IC
                    On the 95859 datasheet each side has 10 pins
                    Pin 6 to 10 deal with current sensing, the processor itself has resistance for 40 to 140 ohms, so for 95869 it is very likely the 5th does anything but related to current sensing
                    Actually there is full data sheet for this IC but hidden behind a wall. To download it Renessas has to approve your purpose, else you wouldn't get the download link
                    Is it better if I start new thread in the schematic request to ask for this ic pinout ?
                      Yes - may be a good idea to post on a fresh thread.
                      Can you share all silk screen markings on your logic board ? Perhaps there is a schematic floating out there.
                      We run a hardware design company and have close ties with Intersil but they are quite strict on releasing such documents. We attempted to source the ISL9240 details when the component was not available for the macbook repairs. Now, of course, everyone in the street corner has the parts available in Asia. It is a double-standard. NDA (non-disclosure) documents mean zero to offshore companies.
                        For the silk screen check Post number 5
                        there isnt any meaningful information behind stickers
                        So all relevant information I believe is what you can see in the photos
