DA0ZQFMB6F0 REV F no power
  • kalilinux25
    replied
    Re: DA0ZQFMB6F0 REV F no power
    Originally posted by mielta View Post
    you can try an new one but
    i think its CPU
    can I tell it by just using oscilloscope?
  • mielta
    replied
    i think its CPU
  • kalilinux25
    replied
    maybe a bad sio chip?
  • kalilinux25
    replied
    unit now doesnt takes any amps if power is pressed
  • kalilinux25
    replied
    Pin 119 on EC Chip susb# when you switch Powerbutton on
    Nothings happens sir 0v
  • mielta
    replied
  • kalilinux25
    replied
    you can try flashing EC Chip you find it in Biossection
    EC_PWROK- 0v same after flashing bin and ec
  • kalilinux25
    replied
    Ok I would Try it sir
  • mielta
    replied
  • kalilinux25
    replied
    pin 112 must be 3,3v when you press Powerbutton
    3.3v and goes to zero. Taking only 33mAmp on supply then goes 0
  • mielta
    replied
  • kalilinux25
    replied
    than you have EC power in first post you wrote you miss EC power
    check Pin 107 and 112 from EC chip
    107-3.3v
    pin 112- 0v
    thank you also sir
  • mielta
    replied
  • kalilinux25
    replied
    check pin 26/50 from EC chip (IT8987E)
    pin 26 is 3.3v
  • mielta
    replied
  • kalilinux25
    replied
    Check PR30 at Page 22
    and search the PDF at 680_LDO and than check the way to +3V_LDO_EC
    pr30 no stuff
    c417 pin 1
  • kalilinux25
    replied
    680_LDO -3.3v
    d17 - 3.3v +3V_LDO_EC
  • mielta
    replied
  • kalilinux25
    replied
    hi
    check pu7 mesuremants
    pin
    1- 6.72v
    2,3,4,5 -19v
    6,19,20 -3.3v
    7,8,1 - gnd
    9- 3.0v
    10,16,15,- nc
    11- 4.5v
    12-3.3v
    13 - 0.6v
    14- 3.3v
    17 - 3.3v
  • mielta
    replied
    Hi
    Check PU7 mesuremants
