ACER NITRO 5,Issues after PCH installation
    ACER NITRO 5 , AN515-55, CORE I5-10300H, GTX 1650
    SN : NHQ7MAA00B117150E63400
    SNID : 11708624634
    PCH gets shortcircuited after laptop screen replacement.
    After new PCH is installed, laptop takes forever to boot, wifi doesnt work, laptop crashes after minutes, fans on full speed and laptop fans and keyboard light still on after shutdown.
    BIOS is flashed and new firmware is installed on it. Only problem now is laptop still crahses after minutes, wifi still doesnt work, and sometimes laptop cant boot saying no bootable device found.
    Re: ACER NITRO 5,Issues after PCH installation
    cleaned me? pch got installed? maybe it has gone bad. sounds like a failed bga-chip replacement.
      I would also say that the culprit is most likely the ME region not being cleaned. You need to dump the BIOS via a programmer and put a clean ME region into it and transfer all the settings from the old one.
      Better said than done though. There are lots of guides how to do it, so do research before doing it.
        bad pch or badly soldered
          SNID : 11708624634
          Hello, have you manages to get it done ?
            I have the same issue and after replaced the PCH twice still the same. once try to boot restart itself
              And did you try cleaning the ME firmware, its essential to do that after changing the PCH. Where did the PCH come from,donor boards or somewhere else
                Hello, yes i did cleaned ME region. it came from a donor board ( asus motherboard )
                  What model is the asus motherboard.Post the silkscreened part number,and a picture of the barcode sticker or square white QR code, if there is one
                    What model is the ASUS motherboard. Post the silkscreened part number, and a picture of the barcode sticker or square white QR code, if there is one
                    it is Strix G532LWS
                    I Have tried another PCH ( SR8HQ ) from another faulty acer nitro and it seems to works but still have issue with the graphic driver. Keep come back with error 43. any idea !!!
                      it is funny as I have here more than one laptop with the same issue.
                      Lenovo legion 7 replaced the intel chipset ( SRJAU ) after cleared ME region still gave a graphic error code 43 as well.
                        it is Strix G532LWS
                        The Asus PCH and bios has Bootguard 5 FVME-5,possibly why it wouldn`t work, i checked a bios in this thread https://www.badcaps.net/forum/showth...hlight=G532LWS
                        The AN515-55 doesn`t have bootguard enabled, FVME-0 .
                          Thank you.
                          I will check that
