New Mina T2 activiation
This topic is closed.
    hello guys,
    I was just informed Mina has released an update for new ibridge Os for t2 intel macs. have anyone tried if it's working and can old serial numbers be used?
    Re: New Mina T2 activiation
    Originally posted by bluestone View Post
    hello guys,
    i think yes can use but update first new ibridge after activate as he share instruction.
      No you can't use old SN it's a new service, You have to register again even if you already registered it for old solution
        Correct today i bypass 2 Macbook its work good for solution is different trick.
          T2RActivator - Macbook
          Has anyone tried the new mina T2RActivator with the old known serial numbers?
          The new version claims to work with newer bridgeos versions.
          Noticed the old thread has closed...
            Re: T2RActivator - Macbook
            Seems iPU MACBOOK T2 ACTIVATOR is doing it too..
            Did someone have some luck to retrive user info from a T2 MacBook editing the file "FMMAccount.plist.plist" as iRizwan explain in the last post ? scp or commands list to retrive files from a jailbreak t2 device and path where is stored?
              Yes the new version works with Latest BridgeOS.
              As i said above you can't use Old Serial to this one, even you can't use same New Registered Serial to any other MacBook.
              They got aware of the trick people used in the past so bye bye cloning SN.
                IPU and others like this can just extract user info etc. from not erased Macbook nothing else.
                  Are you sure about that ? i mean you tired to activate other mac and it didnt works ?
                  thanks in advance
                  N A P S T E R
                    thanks in advance
                    imranromi in post #4 he said that he can bypass 2 macbooks with some tricks.
                      can you explain please ?
                      N A P S T E R
                        This thread is closed. Youtube links to channels with paid unlocking services are against the site rules.Advertising or self promotion of any paid unlocking will also not be tolerated.
