IdeaPad 5 15ALC05 bios please!
    Originally posted by azazazaz View Post
    Hi!
    This time I used NeoProgrammer. Hope it is fine.
    no, is not. I told you to do more readings and compare them, open 2 readings in HxD and use Compare function.
      Hi !
      Just a question. Do i need to plug in the bios coin battery? Cos I have unplug both the main battery and bio battery.
        Hi !
        no
          no
          Hope this is ok .. thank you
            bump
              bump
              ideapad 5-15ALC05 Laptop - Type 82LN
              Become a Badcaps supporter
              Thanks to all supporters.
                Hi hoaca388
                Serial is PF2X5P8J
                Model : Lenovo Ideapad 5 15ALC05
                MO : PF9XB1530160
                MTM : 82LN00EMSB
                S/N : PF2X5P8J
                Thank you !
                  Lenovo IdeaPad 5 15ALC05
                  NM-D701
                  MTM: 82LN00M7PB
                  SN: PF3LRYL1
                  Please repair BIOS no display
                    NM-D701
                    MTM: 82LN00M7PB
                    SN: PF3LRYL1
                      NM-D701
                      MTM: 82LN00M7PB
                      SN: PF3LRYL1
                      Previous bios dump was not correct, please repair this one original from device
                        NM-D701
                        MTM: 82LN00M7PB
                        SN: PF3LRYL1
                          Originally posted by hardware1 View Post
                          Re: IdeePad 5 15ALC05 bios please!
                          Here's your New Bios, it's a Virgin Bios from Lenovo with your DMI.
                          thanks so much, work for me
                            You're welcome
                            all donations are welcome,
                              Lenovo ideapad 5-15ALC05 Laptop - Type 82LN
                              I've tried one of the BIOS files here but still not booting, I assume I need DMI info or something.
                              I've attached my BIOS below, could someone please try fix this for me?
                                Check hardware issues.
                                  The laptop was turning on fine but I believe I switched it off during a BIOS update. I've removed everything from the board and it still doesn't turn on. (Power light comes on, fans don't spin and no display).
                                  Did the BIOS look fine to you is that why you've recommended that?
                                  Edit Chip Model - w74m12jwssiq
                                    Bump.
                                    I really need this done, if you guys don't want to do it could you teach me how?
                                      Bump.
                                      you have everything you need for the post#11
                                      https://www.badcaps.net/forum/troubl...hlight=15ALC05
                                        I copied my DMI info as described for an ideapad in post # 55 here. Didn't solve the issue but I guess I'll try the flex BIOS if you think that'll work.
