dump ideapad 3-15ITL6
    Hello everyone, I have a Lenovo IdeaPad 3 14ITL6, the serial number PF39T7XF
    It was updating the firmware via Windows update, and there was a power
    outage in my area due to a fuse blowing. And my battery was almost depleted
    because I had not used the laptop in a while. Long story short, it's all messed
    up and keeps boot looping. I have got the bios. Fd from the bios available on
    the website was renamed with ten different names seen on the forums, and it
    also had a combination of other names along with fd and bin extensions. Still,
    nothing seems to work fn-+r appears to make the charging LED blink orange.
    Still, nothing happens, and neither does the USB stick light up. It doesn't seem
    to be reading. Now I know I can use ch341a programmer and get done with it
    Still, I am unfamiliar with backing the old bios and flashing new ones. Still, this
    model seems to have two chips for bios, one eight mb and one 16mb. Also,l
    read something related to intel ME region but couldn't figure out how all that
    must be done. I request any help possible. I really could use some help.
    • peste
      peste commented
      Editing a comment
      merged post..
    you have everything you need at the post #14..
    you need an SPI programmer..here is a video as an example...https://www.youtube.com/watch?v=DWWigscuQDY
    make a copy to both bios chips before writing or reading.. so as not to lose the DMI information..
      Originally posted by peste View Post
      you have everything you need at the post #17..
      I am aware on how to read and backup original bios but unsure how to paste DMI information onto the new bios. Thank you
        use the HxD program (you can find it for free)...enter both bios in the program (of the laptop, and the virgin one from the website), select the interval from post #14, where the DMI interval is passed and (COPY-PASTE) from the bios- the laptop, in virgin bios... and that's it..
          Lenovo Ideapad 3 14ITL6 Bios Needed
          Bios Issue ... When I turn on the Laptop .. Its only flashing the power led 12th times
          I searched and tried 4 dumps found here for my Lenovo and All of them are not worked with me ..
          Laptop Lenovo Ideapad 3 14ITL6
          Board Number: HS460 HS560 HS760 NM-D471 Rev:2.0
          S.N: PF4G4CZA
          MTM: 82H701QQLM
          Here is My old dump
            S.N: PF4G4CZA
            MTM: 82H701QQLM
            Here is My old dump
            you have everything you need for the post#14..
            https://www.badcaps.net/forum/troubl...l6#post3299726
              Lenovo ideapad 3-15ITL6 NM-D472 rev 2.0 with video chip N17s-g5-a1
              I deleted the old onbard RAM 4 chipc 1Mb D9WWP . But I have no the same chips and install 4x1Gb Samsung.
              The laptop turned on and I saw on the screen 4Gb. BUT!!! The laptop does not see external memory!
              Schematic with vershion 0.1 dont work. changing straps ID 8, 9, 10 11 no changes with external memory.
              8Gb on board with 4x2b Micron also dont work.
              Can Y help me wright the BIOS with no onboard RAM?
              Or write the BIOS wiht 4 chips D9ZFW and 8Gb onboard RAM ?
              BIOS amd EC ver GGCN20WW
              S/N PF30TZD5
              MTM 82H8009WRE
                S/N PF30TZD5
                MTM 82H8009WRE
                Try this patcher - https://www.badcaps.net/forum/troubl...20#post3232220
                  I have a Lenovo IdeaPad 3 15ITL6 (SN: pf4fx6bk, MTM: 82H803KERA) with two identical W25R64JVS1Q chips, each 64 Mbit, which differs from the usual configuration with one 8 Mbit chip and one 16 Mbit chip. Is this a standard setup for this model?
                  The main issue is that the BIOS password is locked. I have downloaded the BIOS dump (two 8 MB files) and need to reset the password. What steps should I take to do this? Can I use the dump to reset the password, and which tools would you recommend for this?
                  Thank you in advance for your help!
                    Are you sure both chips are the same size. Look at the part number on top of each chip. Your UB3 (16MB) is the bios region and looks ok. Your UB1 (16MB) is 2 different 8MB backups written twice, so you or someone else has made a mistake, the chip is or should be 8MB.
                      Thank you for your prompt response and attention to my issue!
                      You were absolutely right—upon rechecking, the chips are indeed different. I have reread them and attached the dumps to this message for clarity.
                      Could you please let me know what additional steps I need to take to remove the BIOS password? Is there any specific tool or software you would recommend for this process?
                        Bios. Flash both
                          Bios. Flash both
                          Thank you very much, you helped me a lot.
                            Lenovo Ideapad 3 15ITL6 Bios Needed
                            Bios Problem... When I turn on the laptop... Only the power LED blinks 12 times
                            I have tried many files found here with ch341a but the same problem persists
                            Card Number: HS460 HS560 HS760 NM-D471 Rev:2.0
                            S.N: PF4BH6EA
                            MTM: 82H80369TX
                            Here's my old dump
                              S.N: PF4BH6EA
                              MTM: 82H80369TX
                              Here's my old dump
                              you have everything you need at post #14.....
                                hi i tried this time the power led is on steady for 12 seconds no image or fan
                                  Either you wrote the content with errors, or the laptop has another problem.
                                    Hi please help to transfer the dmi to new bios, I am attaching the old broken bios it has both 8mb and 16mb
                                    Serial Number is PF39T7XF
                                    Also if you can give me instructions how do i flash both bios is there a specific order that i need to follow, wherein i need to flash 16mb first and then the 8mb or it does not matter? As well as do i need to erase the chip before i flash the new bios how does that work?
                                      you have everything you need at post #14.....It doesn't matter the order in which you write the chips.
                                      use the HxD program (you can find it for free) enter both bios into the program (e.g. the 16MB one of your laptop and the 16MB one from post 14) because this chip contains the DMI, which you need to transfer, copy the DMI interval from post #14 and (copy -paste) from your bios into the bios from post #14 which is virgin... that's all.. write the 8MB one directly from post #14..
                                      You can also find a tutorial on this here.
                                        I do not understand how the copy and paste works in the HxD program, I tried it yesterday but how do I make sure that the new bios has all of the dmi that it needs how do I compare, because I tried to find serial number even on my old bios dump but I could not find it, the rest of that is clear
