plz help me to repair Thinkpad A475 nm-b351 bios bin
    plz help me to repair bios bin for think bad da475 nm-b351
    lab start but uble to boot windows or enter setup menus
    Re: plz help me to repair bios bin
    Write your Device Model and Serial Number.
    What do you mean by "Laptop start but unable to boot to Windows or Enter Setup" is the device has a Password? or it stuck on logo?
    all donations are welcome,
      lenovo thinkpad a475
      s/n pf-11kbqf
      device stuck on logo and keep restart have no password on bios when i press f1 to enter bios menu the device restart
        s/n pf-11kbqf
          s/n pf-11kbqf
          Here's your New BIOS, it's a Virgin BIOS from Lenovo (According to your Serial Number).
          Always remember to add your device model and motherboard number to the thread title.
            thank you so much its working perefct
              Good to know, You're Welcome.
                Lenovo A475 Error 0285 TPM initialization failure
                Hi everybody,
                I hope that I don't make a mistake by creating this thread : if so, I'm sorry...
                I had problem with a lenovo A475 model 20KM with AMD PRO A12.
                After an update, it doesn't boot and I have a sound error code : 0285 TCG compliant functionality related error (might be the TPM initialization failure) and the Lenovo PC Diagnostics Apps indicates to replace the motherboard ...
                The screen stays black, impossible to enter the bios or to do anything else.
                Do you think it will be possible to fix it and how : I don't find any solution on the Net yet ?...
                For information, I can make a bios dump if necessary.
                Thanks a lot ans best regards
                  Re: Lenovo A475 Error 0285 TPM initialization failure
                  Originally posted by Lornet View Post
                  Hi everybody,
                  Please read the rules before posting again to know what to do when you make a request, and not to make more mistakes so I don't have to move your thread again:
                  Add motherboard number, device serial number, and attach your bios dump - doesn't matter if it's corrupted (as in your case) or not. By doing this you increase the chances of getting quick and accurate help in solving the problem.
                  Become a Badcaps supporter
                  Thanks to all supporters.
                    Re: plz help me to repair Thinkpad A475 nm-b351 bios bin
                    Hi VESKO and all of you,
                    I send you my actual bios (save several times with différents software and compare with HxD.
                    Thanks for your reply and best regards
                      And the device serial number is ...?
                        help lenovo a475 motherboard nm-b351 serial number SL10P41431. only the power button and charging led blink
                          Recheck sesrial number
                            That is the serial number that appears on the casing. but tomorrow he verified it
                              Hello, good afternoon, sorry for the delay, I hadn't had time. This is the serial number PF-1PQJ8K
                                A475 (Type 20KL) Laptop (ThinkPad) - Type 20KL
                                  Thank you very much for the help. but it didn't work, I programmed it first, pure bios, it did the same thing as soon as I connected it flashes 3 times on. Then I programmed ec chip it8186vg and it did nothing. Return to the original ec and the ignition flashes 3 times again. I include the original ec to see if the problem is there
                                    Please help me. I need BIOS binary for my Thinkpad A475 NM-b351.
                                    1) I tried to upgrade my bios using USB but failed (screen just turn black).
                                    2) I tried to flash bios using CH341A but I don't have the binary bios file (the bios body). After deleted the old bios, then failed to flash a new bios (don't have the body bios).
                                    3) Now may laptop bricked.
                                    Please help me to flash again my bios.
                                    Thanks.
                                      Thanks.
                                      flash bios from post #5 if no luck than try from post #16
                                      make sur you attach or connect your clip properly to the bios chip pin
                                        Thanks for your reply.
                                        But the bios file is 16MB is it ok? Because I tried to use the one download from Lenovo ($0AR0400.FL1) before but when I tried to flash got error exceed chip size something like that.
