I need BIOS for ASUS Zephyrus GA503QR-211.ZG15
    Hello everyone, I need help with an ASUS ROG Zephyrus G15 GA503QR-211.ZG15. When I connect the charger, the hard drive LED only turns on for a few seconds and then that LED turns off but the fans do not turn or the processor heats up. I wanted to reset the bios but I can't find the bin file.
    the motherboard is GA503QS_main_board R2.3
    Re: I need BIOS for ASUS Zephyrus GA503QR-211.ZG15
    Here's your New BIOS file, it's a Virgin BIOS from ASUS with your DMI and Windows Key.
    Serial Number: M9NRKD002124366.
    all donations are welcome,
      Thank you very much, I'm going to try it, I hope it solves the problem. very grateful to you
        ga503qs_main_board R2.0
          Off topic,this thread for the GA503QR
          Please read the rules before posting again - https://www.badcaps.net/forum/showthread.php?t=103570
            Hello, I have the following problem: my motherboard was broken, and I bought a replacement motherboard and installed it. After the installation, the serial number was displayed as N/A. Beforehand, I saved the BIOS from the old motherboard's chip and then flashed it with an updated BIOS file that included the serial number of the old board. Since then, the serial number is shown in the BIOS, but ever since I installed the new motherboard, I can no longer change the RGB lighting of the laptop; it stays permanently red. I hope you can help me. Attached is the file I flashed.
            • peste
              peste commented
              Editing a comment
              post merged..
            post S/T..full name and model, motherboard model,etc..
              ASUS Zephyrus G15 GA503QR-211.ZG15 ( BestBuy Modell with RGB Keyboard)
              Mainboard: GA503QS
              rev. 2.0
              SN: M4NRKD005513156
              CN: SW3H
              specs:AMD Ryzen™ 9 5900HS - 24GB RAM ( 8GB soldered to the board) - 3TB SSD - NVIDIA® GeForce® RTX 3070
                Mainboard: GA503QS
                rev. 2.0
                SN: M4NRKD005513156
                CN: SW3H
                why don't you post working bios from new motherboard without serial and we'll transfer DMI to it ...
                  The BIOS file that I attached above is the one that is currently on the laptop and has been flashed.
                    well, this bios you attached made your RGB kb not working, so post bios backup from new motherboard without serial with which your kb worked. Also post a picture with QR code from your new motherboard, it's possible to be GA503QR
                      The keyboard backlight has not worked with the new motherboard from the beginning and only lit up in red. With the old motherboard, the keyboard lit up in RGB. I have a BIOS backup of that, which I can upload here.
                        yep, as I suspected ...
Name:	Screen Shot 2024-12-29 at 13.10.52.png
                          Ok what you mean with your suspicion?
                            you can clearly see in picture, one bios is for GA503QS and other is for GA503QR.
Name:	Screen Shot 2024-12-29 at 13.10.14.png
                              Ok so I need than the BIOS for the GA503QS so that the rgb is fully working?
                                Or what can i do to fix this problem?
                                  use tools WBT-313
                                  C:\WBT-313\X64\Keyboard_Light_enable.bat
                                    Originally posted by noname2024 View Post
                                    use tools WBT-313
                                    WBT-314 https://www.badcaps.net/forum/troubl...93#post1611993
                                    Can you post that "Keyboard_Light_enable.bat" file, rename it as txt or post it in a zip file please
                                      wbt -c cnfg /w dd 7e
                                        SMDFlea commented
                                        Editing a comment
                                        Thanks. I thought it might be different to what it was previously but youve confirmed it`s the same command.
