heklp me to unlock it hp 650 g9
hp 650 G9 PASSWORD
You MUST:- Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
I have an HP :
Product name : Elitebook 650 G9
S/N : 5CD31249PV
Would you please help me?
Thanks a lot for your reply
Provide a BIOS/EC dump if possible
Attach files directly to your post instead of linking to external websites
Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms
Originally posted by Heist View PostHello,
I have an HP :
S/N : 5CD31249PV
Become a Badcaps supporter
Thanks to all supporters.
Originally posted by minotaur84 View PostHI. Please help unlock bios password on HP 640 G9 SN - 5CD3264405
after attempting to program both SPI and EC chips laptop stopped booting.
Dumps might be corrupted
Thank youAttached Files
Originally posted by minotaur84 View PostThank you. The laptop still won't turn on. When the power on/off button is pressed Capslock blinks 7 times. Can it be an EC firmware issue? Can you please have a look at mine
Try againAttached Files
Thank you
Serial Number: 5CD3264405
Product Number: 876U9EP#ABG
CT Number: PPUZH108JI81FL
Description: HP EliteBook 640 14 inch G9
BuildID: 22WWRTDZ601#SABG#DABG
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbhcAfPgSguhKjhk8mEn7nVpDpFpTpnpqprqjqz.2D
MAC Address : F4:6D:3F:E3:F5:E9Attached FilesLast edited by rex98; 04-11-2024, 01:23 AM.
I checked the soldering and the surround components look fine for me. flash original dumps back but still no luck. this happened after programming ec chip. Keep in mind that I took original images using an adapter without desoldering from the board, so the dump cannot be read properly. I shouldn't have done that. can you please have a look at itAttached Files
I have a HP Elitebook 650 G9, where I made a dump.
I found on the internet that I need to edit the EC Bios. Something starting from Active till blank rows, which worked for a 840 G8 the guy was using, but didn't work for mine kept getting the 903-Computer Cover error.
It was worth a try and now i'm also stuck here after the 903 error it goes to the screen to enter the admin password.
I wonder if someone can help me with the edit of the dumps.
HP Elitebook 650 G9
Serial: 5CD2522079Last edited by ShadXo; 06-12-2024, 02:41 PM.
HP Elitebook 650 G9
Serial: 5CD2522079
use BCU. you can permanently disable Absolute lock in BCU.
here's your DMI:
Serial Number: 5CD2522079
Product #/SKU: 6N4K3AV
CT Number: PRDQB028JHJ00N
Description: HP EliteBook 650 15.6 inch G
BuildID: 22WWRTCT601#SABH#DABH
Feature Byte: 476J6S6b7B7H7M7Q7W7m7saBaEapaqauawcAdpdqeMfPgSguhKjhk8mEmVn7nVpDpTpqqjqz.r8
MAC Address : A0:29:42:BB:40:B8Attached Files
Originally posted by rex98 View Post
first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
here's your DMI:
