HP 840 G8 Bios Unlock
    Re: HP 840 G8 Bios Unlock
    Originally posted by il60 View Post
    thanks !!
    so the front bios, not need to change it ? simply replace it and just program bios chip back ?
    replace only chip back.
    Become a Badcaps supporter
    Thanks to all supporters.
      Please remove the absolute lock. i already unlocked the bios password.
      unlock the mpm mode.
      sn: 5CG21131TG
        sn: 5CG21131TG
        so after a few trial and error i figure out how to remove absolute in this sh*t.
        first thing you need to do is unlock the bios password.
        in this block address from 00037000 to 00037930 use any hex editor fill with hex (ff)
        then use this patched main it will auto recover DMI and unlock the absolute lock. it also works in no display/ late display no need Rebuild.
        at first boot it will promt final step of bios update. be patient
        no need to reset security defaults. it will promt controller error just enter and it will also promt identity mismatch but its okay just click enter and viola its done.
          or you can use BCU (after unlock bios) to read config and change Absolute * from Lock to *Unlock, save file and write new config file. Also you can permanently disable Absolute in config file.
            asalam o alykm
            post no 36
            i tested working
            once given end point security or e c secirity error but after words laptop turns on and its good now worked perfect alhamdulillah...
              Hp elitebook 840 g8
              hello there can any body unlock this bios thanku
                Re: Hp elitebook 840 g8
                You MUST:
                • Post under a related thread if it exists
                • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 )
                • Provide a BIOS/EC dump if possible
                • Attach files directly to your post instead of linking to external websites
                  Hello, i have an 840 G8 with admin password i need unlock
                    SMDFlea commented
                    Editing a comment
                    Read the rules,post the serial number
                  #49
                  Hello my dear friend! Can you help me unlock the BIOS of another laptop? RCUnlocker did not work.
                  Model: HP EliteBook 840 G8
                  S/N: 5CG21417FM
                  Board-Model: 6050A3426501-MB-A02
                  ProdID: 613Q1UT#ABA
                  Chip-model: Winbond 25Q256JVEN
                    S/N: 5CG21417FM
                    ProdID: 613Q1UT#ABA
                    Here you are
                    • kubat
                      kubat commented
                      Editing a comment
                      Hello my dear friend! It seems that I accidentally removed and lost one diode near the chip, now the laptop does not turn on. I can't say the result of the firmware.
                    #51
                    hi can someone help me to unlock My HP G8 840 i5 th generation
                    S/N: 5CG23037T6
                    ProdID: 4V1P3EC#ABD
                    S/N: 5CG23037T6
                    ProdID: 4V1P3EC#ABD
                    Sorry!
                      At 1st boot press F10 and RESET BIOS to factory defaults
                      Last edited by qayyum786; 01-17-2024, 01:11 PM. Reason: correction in new unlocked bios
                        Originally posted by Vesko356 View Post
                        Here you are
                        Hello! The service installed the resistor I needed, which I accidentally removed. But unfortunately the laptop does not turn on with the original and unlocked BIOS. The diode on the Caps Lock button lights, and the diode on the charging port blinks white, power button doesn't turn on. I think the problem is with the BIOS, what can you advise?
                        Here are the original bios:
                          thank you alot it work perfectly good job
                            HP 840 g8 Bios unlock
                            S/N: 5CG3442C15
                            Board-Model:6050A3426501-MB-A02
                            ProdID: 6L8D7EC#ABA
                              Hello, I have this HP Elitebook 840 G8 with Admin Password
                              S/N: 5CG134CBTW
                              Please, help me remove it. Attached, see the bin. Thank you.
                                S/N: 5CG134CBTW
                                ok
                                  Thank you Rex98, your bin file worked to perfection.
                                    HP Elitebook 840 G8, please remove the password.
