Lenovo Yoga 11e(4th gen) bios
    YOGA 11e
    Board Code: DALI8GMB6D0 REV D
    Plz clean this bios, Backup attached
    Re: Need Yoga 11e Clean Bios
    What issue
      Originally posted by okrpkcomp View Post
      yoga 11e
      board code: Dali8gmb6d0 rev d
      plz clean this bios, backup attached
      thanks
      your clean txe version 3 file
      with rsa sign key
        Thanks sir, its working fine
        Fault was late display and auto shutdown after 5 mints and sometime no post
        how u did this, will u share pls
          I need Lenovo yoga 11e bios bin file This laptop is from another repair shop the bios on board is not even being detected, is totally damaged, 100% confirmed so I do NOT have the original BACKUP, the below information is all that I can get,
          motherboard: DALI8KMB8D0 REV D
          Type: 20HS
          Can't find the serial number so if you are able to work with the above information and give me a working bin I will be highly grateful
            Re: Lenovo Yoga 11e(4th gen) bios
            https://www.badcaps.net/forum/showthread.php?t=92907
              Thank you but the link is for lenovo e145 do they share the bios?
                Same motherboard with you just have to experiment
                  Unfortunately, it does not work, also the motherboard number is not the same. This one is DALI8 the other is DALI2
                    Type: 20HS
                    did you try this???
                    https://www.badcaps.net/forum/showth...ht=DALI8KMB8D0
                      Thanks peste. With this the fan spins at full speed with no display, one question the broken bios chip that was onboard is mxic25l12873g I have used Winbound 25q128fv, is that okay?
                        try..
                          Re: LENOVO BIOS AUTO-PATCHER for Supervisor Password Removal
                          Hello, can you help me with password protected bios? I try it with autopatcher, but it doesn't generate me patched file (i didn't find generated file).
                          Lenovo Yoga 11e
                          TYPE 20HS-S08F00
                          S/N LR-09GRKY 17/07
                          • snaks
                            snaks commented
                            Editing a comment
                            Can you help me,please????
                          • snaks
                            snaks commented
                            Editing a comment
                            I fix it with older version of python.
                          HI CAN ANYONE DO CLEAN ME REGION FOR THIS BIOS IT TAKE SO LONG TO START
                          LAPTOP MODEL LENOVO YOGA 11E
                          BORAD NUMBER DALI8KMB8D0 REV D
                          SERIAL NUMBER SL10M89582
                          try
                            with rsa sign key
                            Thanks 100% working for me, I tried on 2 laptops, working on both
                              I use a bios bin from here.after flashing bios mainboard hv no power.3v and 5v and 1v also present.powwr button hv volt and battery connector hv data clk 3.3v also.after pressing reset botton power supply show 0.045 load.before flash a bios ,there is no display issue.thwn reflash old backup file same condition,no power.then I noticed this mainboard is hv ci5 7th gen CPU DDR4 RAM.any suggestions please,
                              This
                                SMDFlea commented
                                Editing a comment
                                type and post the laptop serial number.....
                              Type,--20HS-S00Q00. S/N LR-09JF0W 17/07
                                Yoga 11e 4th Gen Laptop (ThinkPad) - Type 20HS
                                Become a Badcaps supporter
                                Thanks to all supporters.
