help I need bios HP ZBook Fury 15.6 inch G8 LA-K771P REV:1.0
    Re: help I need bios HP ZBook Fury 15.6 inch G8 LA-K771P REV:1.0
    I am including BIN from both chips just in case.
    Serial# CND2203G2Y
    Thanks.
      Serial# CND2203G2Y
      Thanks.
      Program this chip only, leave the other as is. At first boot enter the bios and reset bios settings to factory default, then reset security settings, then apply, restart and you're good to go.
      Become a Badcaps supporter
      Thanks to all supporters.​
        I will program the chip tomorrow and report back. Regards.
          After reprogramming UK2 chip, when I press power button, I get caps lock blinking 7 times.
            Most probably you didn't program the chip properly, do it again, use verification, read the chip after that and compare the content. Check the soldering of the chip and surrounding area for blown/moved components.
              Unsoldered UK2 chip, read the data off it, then compared to the BIN you provided. No difference. Applied resoldering. Now, I am getting keyboard lights up, then caps lock and num lock both flashing 3 long and 2 short flashes.
              So, I used a different similar BIOS chip this time. I also had it reprogrammed using the BIN you provided and I am also getting caps lock and num lock both flashing 3 long and 2 short flashes. I already resoldered like 5-6 times and I am getting the same result.
              This flashing pattern indicates memory issue but I am using original memory chips and tried others I had handy. Still the same issue.
              Is it possible the BIN file is the culprit? Looking for answers.
                Hello, could you help me to remove the BIOS password?
                Serial: CND210375R
                Thank you, I already managed to unlock it, absolute appears inactive, could you disable it permanently?
                  Hi, requesting bios for ZBook Fury 15.6 G8 LA-K771P Rev 1.0. Laptop starts up and says "updating bios", it restarts and loops on "updating bios" over and over.
                  Serial Number: CND2252D4K
                    i need help unlocking a dump for hp zbook fury 15inch bn gpz50 la-k771p rev 1 tried hp unlocker wont work with 32mb bios and nvram method seems not be suitable for this model
                    thanks in advance
                    sn:cnd2203l49
                      update i remove the absolute and admins password,NvramActiveRegn method works with the dump from 2nd eeprom thanks !!!
                        Hello all, could someone please remove the password, I have been looking at other dumps before and after with beyond compare
                        nothing is in the same place and I am just not confident in myself just yet at giving this a go.
                        S:N : CND2402G3Q
                        Thanks.
                        Try
                          Thanks a lot mate, will give these a test soon.
                            hello sir we need 15.0.42.2235_COR_H_B stock file
                              Hp Zbook Fury 17.3 inc G8 With admin password can please unlock this..
                              SN# : CND3111FFD
                              PROD ID : 546D2EC#ACJ
                                SN# : CND3111FFD
                                Try this https://www.badcaps.net/forum/troubl...41#post1793941
                                  not working sir i will upload main and ec dump file can u please the bios password..
                                    SN# : CND3111FFD
                                    CAN u please unlock this bios password
                                      SN# : CND3111FFD
                                      Send to you
                                        Originally posted by minhdigital View Post
                                        Send to you
                                        Password cleared but endpoint security controlled error showing
