HP Elitebook 850 G8 Bios unlock
  • Hesley1234
    • Dec 2022
    • 6
    • Nederland
    #101
    Originally posted by m.sabry2110
    try
    Seems not te be working.
    Not booting and after few retries the bios is recovered from the embedded controller because the data in the embedded controller and in the bios flash are different.
    So still need to enter the password...
    Kind regrads,
    Hesley
    • hoaca388
      Badcaps
      • Jan 2022
      • 11684
      #102
      Kind regrads,
      Hesley
      Unlocked
      • Hesley1234
        • Dec 2022
        • 6
        • Nederland
        #103
        Originally posted by hoaca388
        Unlocked
        After flashing the latest dump i get this messages (ordered the pictures in sequence of pop up).
        Could anybody help me?
        Kind regards,
        Hesley
        • hoaca388
          Badcaps
          • Jan 2022
          • 11684
          #104
          Kind regards,
          Hesley
          Post model , serial number .
          • Hesley1234
            • Dec 2022
            • 6
            • Nederland
            #105
            Hp Elitebook 850 G8
            RMN: HSN-141C-5
            ProdID 50B57EC#ABB
            SN: 5CG20854QQ
            Kind regards,
            Hesley
            • hoaca388
              Badcaps
              • Jan 2022
              • 11684
              #106
              Hp Elitebook 850 G8
              RMN: HSN-141C-5
              ProdID 50B57EC#ABB
              SN: 5CG20854QQ
              Kind regards,
              Hesley
              Post Ec file.
              • Hesley1234
                • Dec 2022
                • 6
                • Nederland
                #107
                Post Ec file.
                This is the original bin file:
                • hoaca388
                  Badcaps
                  • Jan 2022
                  • 11684
                  #108
                  This isn't EC file, this is a main bios file.
                  • Hesley1234
                    • Dec 2022
                    • 6
                    • Nederland
                    #109
                    My apologies, this is the file from the flash device on the bottom of the board. U366 this should be EC file?
                    Kind regards,
                    Hesley
                    • hoaca388
                      Badcaps
                      • Jan 2022
                      • 11684
                      #110
                      Kind regards,
                      Hesley
                      Unlocked
                      • chelsea1155
                        • Dec 2014
                        • 26
                        • vietnam
                        #111
                        Hello. i need unlock bios for HP 850 g8.
                        SN: 5CG1351RTT
                        • rex98
                          • Feb 2023
                          • 1273
                          • Mandaue CEBU, Philippines
                          #112
                          SN: 5CG1351RTT
                          first boot press f10 apply factory defaults and exit.
                          use BCU.
                          • Christian Seitz
                            HWK Meister
                            • Dec 2024
                            • 7
                            • Deutschland
                            #113
                            Hello, I hope someone can help me with my password on an HP Elitebook 850 G8
                            System T76 Ver. 1.15.02
                            SN:
                            5CG14043NY
                            SKU: 4L254EC#ABD
                            I have attached all the information and added an image file with all the system information
                            Thank you
                            Christian​
                            • Christian Seitz
                              HWK Meister
                              • Dec 2024
                              • 7
                              • Deutschland
                              #114
                              I noticed that after reading and comparing repeatedly, the EC BIOS is defective. I think the component is defective! Can this be saved without a dump?​
                              • Christian Seitz
                                HWK Meister
                                • Dec 2024
                                • 7
                                • Deutschland
                                #115
                                Read again with another Eprom reader EC
                                • hoaca388
                                  Badcaps
                                  • Jan 2022
                                  • 11684
                                  #116
                                  Unlocked
                                  • Christian Seitz
                                    HWK Meister
                                    • Dec 2024
                                    • 7
                                    • Deutschland
                                    #117
                                    Unlocked
                                    Thank you so much, it's perfect, you're the best
                                    I only have one small problem: on the right side only the USB port where the charging cable is connected works.
                                    From behind
                                    Charging port I.O.
                                    USB I.O.
                                    HDMI I.O.
                                    USB C doesn't work
                                    USB C 2 doesn't work
                                    from behind left
                                    Lock connection
                                    USB doesn't work
                                    Mic headphones I.O.
                                    But everything is activated in the BIOS
                                    Do you have another idea?
                                    It could be that there is motherboard hardware damage.
                                    It was an employee of my company and was not tested beforehand.
                                    Thank you!​
                                    • tareqtareq
                                      • Dec 2014
                                      • 13
                                      • jordan
                                      #118
                                      Hello. i need unlock bios PASSWORD for HP 850 g8.
                                      5CG22735NQ
                                      • Gabi Darrell
                                        • Jan 2025
                                        • Argentina
                                        #119
                                        Hello! I have the BIOS with a password. I have read everything to dump but I really didn't understand and I can't do it.
                                        I need help
                                        Thank you!
                                        I have the HP 850 g8
                                        Serial Number: 5CG2190QLG
                                        ProID: 52W98EC#AC8​
                                        • hoaca388
                                          Badcaps
                                          • Jan 2022
                                          • 11684
                                          #120
                                          5CG22735NQ
                                          You got the wrong file.
                                          • zenius
                                            by zenius
                                            12-08-2024, 06:13 AM
                                          • STKR123
                                            The right BIOS Programmer - The right software (HP Elitebook 820 G1, 840 G2) no soldering, EC, DMI, ME
                                            by STKR123
                                            Greetings badcaps community,
                                            I havent done this for a long time and want to start it all again, after some evil and annyoing illness.
                                            So I apologize in advance, if some phrases might sound a bit like gibberish or illogical to you.
                                            Im trying my best to fully describe what I plan to achieve and hope I was choosing the right sub-forum for my new adventure.
                                            I have a Elitebook 820 G1 and a Elitebook 840 G2 here.
                                            These ask for a password when entering the BIOS, but boot just fine from the internal SSD.
                                            I learned that desoldering...
                                            10-29-2024, 06:03 AM
                                          • macabook
                                            by macabook
                                            🧩 Initial Issue
                                            07-24-2025, 02:17 PM
                                          • clrscr
                                            Need unlock bios hp elitebook 835 G11
                                            by clrscr
                                            please help me unlock bios password hp elitebook 835 G11
                                            S/N: 5CG50434RD
                                            thanks!...
                                            06-04-2025, 09:38 PM
                                          • Guest
                                            Elitebook 850 G5 BIOS bricked
                                            by Guest
                                            I have an EliteBook 850 G5. After a Windows update, including a BIOS update, the notebook turns on, but the screen remains black, and the fans spin at high speed—nothing else happens.
                                            I assume the BIOS update failed, so I searched for the BIOS chip.
                                            I found a Winbond chip located between the RAM and the hard drive, which has a size of 32 MB.
                                            However, the BIOS update available on HP's website is only 17 MB in size. I used the update version that was previously installed when the notebook was still working.
                                            Can the corrupted...
                                            03-24-2025, 01:21 AM
