HP Elitebook 850 G8 Bios unlock
    Hello again
    i need unlock bios HP Elitebook 850-G8 11th Gen
    SN : 5CG2083DPQ
    Thank on advance
      Originally posted by mouzied View Post
      Hello again
      SN : 5CG2083DPQ
      Thank on advance
      first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
      use BCU. you can permanently disable Absolute lock in BCU.
      here's your DMI:
      Serial Number: 5CG2083DPQ
      Product #/SKU: 1G1Y1AV
      CT Number: PKPSN00WBG90BY
      Description: HP EliteBook 850 G8 Notebook
      BuildID: 21WWCVCT602#SABD#DABD
      Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUbhcAdUdpdqfPguhKhkjhk8mEmwn7nVngpD.4g
        here's your DMI:
        Super fast thank you so much
          I need unlock Bios Password and Post power On password on HP Elitebook 850 G8, SN: 5CG2421G2B, ProdID 4V0T4EP#ABB
          thanks
            Originally posted by kowalcook View Post
            thanks
            Send to you, first boot press f10 apply factory defaults and restart, 2nd boot reset security settings to defaults and exit.
            here's your DMI
              here's your DMI
              Its worked all good.
              Thank you very much minhdigital
              regards
                Hello, could you please send unlock for:
                Product Name: HP EliteBook 850 G8 Notebook PC Processor: 11th Gen Intel(R) Core(TM) i5-1145G7 @ 2.60GHz
                System BIOS: T76 Ver. 01.13.01 03/30/2023
                Serial Number: 5CG31932Q4
                System Board ID: 8846
                System Board CT Number: PKPSHOOWBI226T
                Thanks upfront for your time.
                Greets, Dihpez
                  Greets, Dihpez
                  Upload bios file
                    Originally posted by Blaze Tech View Post
                    Upload bios file
                    You need a copy/backup of my current bios?
                    I'm not able to backup my bios I've tried verious utils but none seem to do the trick.
                    I've also searched high and low on this and other fora but my knowledge on this subject is limited at best.
                    The attachment is my bios only in version i extracted it from .exe
                    I could use a push in the right direction any advice is more then welcome.
                      https://www.badcaps.net/forum/troubl...21#post1622421
                      https://www.youtube.com/results?sear...e+a+programmer
                      Become a Badcaps supporter
                      Thanks to all supporters.
                        Hi Everyone
                        Could anybody please help in removing bios password on HP Elitebook 850-G8 11th Gen if poss
                        see attached main bios dump.
                        S/N 5CG21454VG
                        M/B 6050A3216701 -MB-A01(A1)
                          Originally posted by Mrnixdorf View Post
                          Hi Everyone
                          S/N 5CG21454VG
                          here
                            Hi Everyone
                            S/N 5CG21454VG
                            Password removed
                              ts worked 100/100
                              Thank you very much​
                                Good day!
                                Please, can you help me with Bios dumps for laptop HP Elitebook 850 G8, mainboard 6050A3216701.
                                Laptop came to me with no start, was soldering both EEprom ICs, serial numbers in readed dump are not same with real, labeled on body. So, original dumps are lost. I've tryied to flash some dumps from this forum, laptop starts with no image, and led blinking.
                                Is it possible to get clean dumps to this mainboard?
                                Real laptop data
                                sn - 5CG2246DLC
                                ProdID - 401F1EA#ABB
                                  Model : hp elitebook 850-g8
                                  serial no : 5CG141C2G2
                                  Prod id : 1G1X8AV
                                  part no : 6050A3216701-MB-A01 (A1
                                  Problem : remove the biosz password
                                    Prod id : 1G1X8AV
                                    here
                                      Originally posted by Rexer Anthony View Post
                                      here
                                      thank you so much sir perfectly working
                                        Hi i have bioss password 850 G8 can you help ?
                                        850 G8
                                        SKU 358P8EA#UUW
                                        Serial 5CG1087BM7
                                          850 G8
                                          SKU 358P8EA#UUW
                                          Serial 5CG1087BM7
                                          here's your DMI:
                                          Serial Number: 5CG1087BM7
                                          Product #/SKU: 358P8EA#UUW
                                          CT Number: PKPSF00WBEV1C1
                                          BuildID: 21WWCVAT601#SUUW#DUUW
                                          Feature Byte: 3X476J6S6b7B7H7M7Q7W7m7saBaEapaqauawbUcAdUdpdqeMfAfPguhKhkjhk8mEmVmwng.Tn
                                          MAC Address : 14:CB:19:0E:50:9E
