Bios for Lenovo Ideadpad Flex 5 14ALC7
    I need bios for this model. The notebook starts with both Esc key and Caps lock on, you can hear the fan starts spinning and the cpu gets quite warm. However, no video. I suspect corrupted bios. Your help is appreciated.
    Serial# PW025QRR
    Re: Bios for Lenovo Ideadpad Flex 5 14ALC7
    Serial# PW025QRR
    IdeaPad Flex 5 14ALC7 Laptop - Type 82R9
    Become a Badcaps supporter
    Thanks to all supporters.
      Thank you, Hoaca388. Computer is up and running now.
        Need bios Lenovo Flex 5 14ALC7
        any one please help me
        i need bios for lenovo Flex 5- 14ALC7 Laptop ideapad
        board id: C570-14A 213112-1
        SN: PW02AEXP
        i have backup bios but no display
        thx all
          Re: Need bios Lenovo Flex 5 14ALC7
          SN: PW02AEXP
          thx all
            SN: PW02AEXP
            thx all
            bios extracted from the help page for
            IdeaPad Flex 5 14ALC7, IdeaPad Flex 5 16ALC7
              thanks a lot, its work
                Thank you very much
                  Hi Glat, janocko, trepachka
                  Can you please explain how did you perform the BIOS flashing?
                  I have exactly the same issue with my "IdeaPad Flex 5 14ALC7 Laptop - Type 82R9" (Serial #: PW03G90G)
                  I downloaded the attached "IdeaPad Flex 5 14ALC7 Laptop - Type 82R9.bin" file.
                  How did you create the bootable USB drive?
                  I'm stuck in the process
                  Any help is much appreciated!
                    Use a programming . For example: CH341A, RT906H, RT906F...
                      Edited:
                      hoaca388, If there's a way you can assist with instructions on how to use the 'bin' file to flash the BIOS that would be hugely appreciated.
                      "Hi Glat, janocko, trepachka
                      I have exactly the same issue with my "IdeaPad Flex 5 14ALC7 Laptop - Type 82R9" (Serial #: PW08HWZ2) Mfg Date: 2023/11/09
                      I downloaded the attached "IdeaPad Flex 5 14ALC7 Laptop - Type 82R9.bin" file but doesn't work, help me please
                      Please i need bios Lenovo Flex 5 14ALC7
                      S/N: PW02P9RG
                      MTM: 82R9CT01WW
                        S/N: PW02P9RG
                        MTM: 82R9CT01WW
                        Laptop IdeaPad Flex 5 14ALC7 - Loại 82R9
                          I have an IdeaPad Flex 5 14ALC7. It has the same symptoms as the laptop I mentioned in post 1: keyboard lights up, fan begins to spin. I applied the file in post 2 but the computer is doing the same thing except the fan comes on much later.
                          Please, help me fix corrupted bios.
                          S/N: PW023CEV
                          MTM: 82R9000QUS
                            S/N: PW023CEV
                            MTM: 82R9000QUS
                            TRY
                              Thank you. Computer is up and running again. I just need to use Lenovo U1 Tool to fill model number, serial number, etc. They are currently showing as INVALID
                                Hey, can you do me a favor and modify the very last bin file you provided in post 16 to include S/N: PW023CEV and MTM: 82R9000QUS ?
                                Lenovo U1 Tool utility is not booting off the flash drive but it works on any Thinkpad notebook I tried.
                                  Bios + DMI
                                    That worked. Thank you.
