lenovo G570 bios dump help
  • asliyucegsm
    • Jun 2011
    • 351
    • Turkiye
    my friend
    lenovo g570 pressing power button LED is lit for a few seconds, then go offthat's just one flash and eprom from this file is used to add friends here
    25x10bv eprom
    25L3206e flash rom
    thanks
  • lord
    • May 2011
    • 319
    • Croatia
    Re: lenovo G570 bios dump help
    Its best to take out the chip and reprogram it on the eeprom programmer
    • AHmad_Salal
      Need BIOS Dump/ROM for Lenovo Thinkstation p500
      by AHmad_Salal
      Hello all,
      I have a Lenovo Thinkstation P500 that is stuck at post with no display, it happened after I changed the memory timings in bios. I can not clear CMOS using the jumper on the motherboard, also tried re-flashing bios suing a USB stick but it also doesn't work. The only solution that I can think of right now is re-flashing the bios chip using an external programmer but the problem is that I don't have the bios dump of p500 for flashing externally and I don't know the location of bios chip. If someone can provide the bios dump and bios chip location it would be really helpful....
      11-28-2023, 05:28 AM
    • Ahari
      by Ahari
      I...
      08-13-2025, 06:12 AM
    • hyperwood
      [REQUEST] 2MB BIOS Dump for Lenovo NM-E471 Rev 2.0 (Winbond 25Q16JWSIQ Chip)
      by hyperwood
      I’m looking for a 2 MB BIOS dump for a Lenovo IdeaPad 5 16ARH7H / Legion 5 with mainboard NM-E471 Rev. 2.0.
      The BIOS chip is a Winbond W25Q16FW (1.8V, 2MB) and it's completely unresponsive / bricked. I tried recovery via USB but no success. Now I want to reflash it externally using a CH341A programmer.
      I already found 32MB dumps (e.g. from Vinafix and Badcaps), but they are too large for the chip – and the last 2MB in those files are just FF FF FF....
      āœ… What I need:
      • A working 2MB BIOS dump
      • Matching NM-E471 Rev. 2.0, e.g. JY575
      06-25-2025, 02:28 PM
    • mkdj
      by mkdj
      Dear all,
      10-19-2025, 04:41 AM
    • Habble7
      by Habble7
      Suspected Cause:
      Troubleshooting Attempts:
      05-22-2025, 07:28 AM
