Originally posted by buglerbalint
View Post
Lenovo Thinkpad T495 AMD bios password locked
Originally posted by bnc_ View PostThanks, it seems I have killed the chip by desoldering and soldering it too many times as it's not even detected by the programmer now. I have ordered a few pieces of the same chip so I could check. I will update as soon as I get them.
Originally posted by volinakis View Post
try and follow instructions from autopatcher.
[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default
Bumping, sadly couldn't get it to work yet.
STEP 9: Reset BIOS settings to factory defaultAttached Files
Originally posted by bnc_ View PostHey,
It's my first time trying this.
I have recently got a T495 (S/N: PF-1ZY53R) with a locked BIOS. I managed to desolder the chip and read it, however I can't seem to get the patched one working with the autopatcher.
I would like to do it myself if possible, however I have zero experience. When I flash the patched version, the notebook plays the music and fan keeps going with black screen. It works when flashing the original dump but still has the password obviously.
Info: I have disconnected the internal display (it doesn't work) cable and I connected an external monitor by HDMI. The original BIOS shows up on the external screen.
Does anyone know what I'm doing wrong? I've attached both dump files.
Thank you in advance.
Hey,
Thank you in advance.Attached Files
Because with the clip I have problem ti CLAMP the IC, do you think this che be good for a winbond 25q128fw?
https://a.aliexpress.com/_EuNeV8J
Sorry I can't try it now because soic8 clip not want to fit on chip 😞 I ordered a new one hoping it fit better
Originally posted by Maxpower3 View Post
flash this bios .
Enter setup with f1
clear password with two blank password and clear security chip
save and exit
after reload your original bios
Sorry but I never do it before.
Originally posted by gsoft View Post
Thank you for answer.
Sorry but I need to understand before doing something wrong.
I need to flash this firmware and the follow the same steps indicated in the autopatcher tutorial?
Thanks again
Enter setup with f1
save and exit
Originally posted by gsoft View PostPlease can you answer me? There is a way to patch the t495 bios? Thank you so muchOriginally posted by Maxpower3 View Post
clear password and security,load by default. restart
and restore original BIOS after
otherwise password disappears foreverAttached Files
Originally posted by AccountSaver View Post
It doesn't work ,what you are asking
You need at least the SVOD4 or the Vertyanov.
Is not possible to patch this bios?
I read other post where people figured out to patch but not with autopatcher. They ask and someone send the patched bios.... Can you help me please?
Originally posted by gsoft View PostHi I need to patch my Lenovo t495 to remove the supervisor password .
I cannot use the autopatcher because the t495 is not Intel but a Ryzen.
I make a dump of original firmware and now I ask your help to patch it.
Please can you help me?
board code: FA495 NM C131 REV. 1.0
board code: FA495 NM C131 REV. 1.0Attached Files
