Originally posted by Markus1741
View Post
Lenovo Thinkpad T495 AMD bios password locked
Originally posted by gsoft View Post
This is the S/N PF-26H4AM.
Why I can't use the soic clamp?
" It is possible to use clips on SOIC-8 ICs to avoid desoldering, however it is *very unreliable* and will often lead to an empty or corrupt dump. Avoid whenever possible.
If you insist on using a clip, then make sure the programmer uses an additional buffer and line driver for SPI.The T48 and T56 has it built-in.
It is recommended to desolder the chip and use an adapter board or socket."Last edited by volinakis; 08-02-2024, 03:46 AM.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by volinakis View Post
this proves once again that you didn't read bios guides! As beginner into bios mod this should be your 1st step, ppl with way more experience than you made that guide. Since you write back bios backup you made with clamps and laptop doesn't start this should tell you that your bios backup is corrupted! And yet you ask "Why i can't use the soic clamp?" !!!
So please let me know why you ask me the serial number? it is possible to generate a new bios dump with it?
Really thanks
Originally posted by Markus1741 View PostLa La ....----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Ok yes I yet read it but I was thinking what you wrote was because I don't use the 1.8V adapter. Now is all clear.
Really thanks----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Great!!!
1000 thanks
[ HOW TO USE THE PATCH ]
STEP 1: Flash and replace current BIOS with the generated patch file
STEP 2: Boot the machine
STEP 3: Press ENTER/F1/etc. to enter BIOS settings
STEP 4: Enter any character when asked for Supervisor Password
STEP 5: Press enter when it shows Hardware ID
STEP 6: Press space bar 2x when asked
STEP 7: Turn off machine
STEP 8: Restore original BIOS
STEP 9: Reset BIOS settings to factory default
at step 8 use T495_new.bin Because your backup is corrupted I'm not sure your DMI is ok, if you get message that serial, MTM, etc. is missing use Lenovo Maintenance Utility to restore original serial, MTM.Attached Files----------------------------------------------------------------------------------------------------------------------------------------------------------------------
1st use patched file to unlock bios following steps described in autopatcher:
I'm trying to power one the laptop with the ch341 clamp attached but not inserted to usb because I'm not able to desolder it and I spend some hours to fit the clamp.
Please can you help me?
The 1.8V adapter just arrive I follow this steps but after patching with the generated patch file (STEP1) the fan start fast but screen stay black and after the laptop shutdown itself.
Please can you help me?----------------------------------------------------------------------------------------------------------------------------------------------------------------------
so ... if you got an faulty bios backup with clamps how do you expect to write bios chipset in a good way ... with same clamps? Think, is for free!
I not want to disconnect the clamp because if I have to flash another firmware I not want to make again 10000 try to fit it.
You are right but it was my mistake because I try to read and flash with the clamp not fitted correctly but now after 10000 try I fit it and bacause I'm not able to desolder it I want to try to restore the laptop in this way. I disconnect the ch431a but not the clamp and now the laptop play some strange sounds (bip bip...) and nothing else
I not want to disconnect the clamp because if I have to flash another firmware I not want to make again 10000 try to fit it.----------------------------------------------------------------------------------------------------------------------------------------------------------------------
Originally posted by SAHILSHAIK View Post
SIR COULD U PLEASE TELL US IN STEPS
https://www.youtube.com/watch?v=3BB--9VU0R0
