Lenovo Thinkpad T495 AMD bios password locked
    Originally posted by Markus1741 View Post
    La La ....
    Sorry I don't uderstand can you explain me?
      Originally posted by gsoft View Post
      This is the S/N PF-26H4AM.
      Why I can't use the soic clamp?
      this proves once again that you didn't read bios guides! As beginner into bios mod this should be your 1st step, ppl with way more experience than you made that guide. Since you write back bios backup you made with clamps and laptop doesn't start this should tell you that your bios backup is corrupted! And yet you ask "Why i can't use the soic clamp?" !!!
      " It is possible to use clips on SOIC-8 ICs to avoid desoldering, however it is *very unreliable* and will often lead to an empty or corrupt dump. Avoid whenever possible.
      If you insist on using a clip, then make sure the programmer uses an additional buffer and line driver for SPI.The T48 and T56 has it built-in.
      It is recommended to desolder the chip and use an adapter board or socket."
        Ok yes I yet read it but I was thinking what you wrote was because I don't use the 1.8V adapter. Now is all clear.
        So please let me know why you ask me the serial number? it is possible to generate a new bios dump with it?
        Really thanks
          La La ....
          once again you try to look smarter than you are! if he wrote back his bios backup and laptop doesn't work what's this telling you?
            Really thanks
            yes, I will try to build a new bios from bios update, patch it and see how it works.
              Great!!!
              1000 thanks
                Great!!!
                1000 thanks
                1st use patched file to unlock bios following steps described in autopatcher:
                [ HOW TO USE THE PATCH ]
                STEP 1: Flash and replace current BIOS with the generated patch file
                STEP 2: Boot the machine
                STEP 3: Press ENTER/F1/etc. to enter BIOS settings
                STEP 4: Enter any character when asked for Supervisor Password
                STEP 5: Press enter when it shows Hardware ID
                STEP 6: Press space bar 2x when asked
                STEP 7: Turn off machine
                STEP 8: Restore original BIOS
                STEP 9: Reset BIOS settings to factory default
                at step 8 use T495_new.bin Because your backup is corrupted I'm not sure your DMI is ok, if you get message that serial, MTM, etc. is missing use Lenovo Maintenance Utility to restore original serial, MTM.
                  Thank you I will try it but to make sure I do things right:
                  I must use the 1.8V adapter and I have to desolder the chip. Is right?
                    The 1.8V adapter just arrive I follow this steps but after patching with the generated patch file (STEP1) the fan start fast but screen stay black and after the laptop shutdown itself.
                    I'm trying to power one the laptop with the ch341 clamp attached but not inserted to usb because I'm not able to desolder it and I spend some hours to fit the clamp.
                    Please can you help me?
                      so ... if you got an faulty bios backup with clamps how do you expect to write bios chipset in a good way ... with same clamps? Think, is for free!
                        You are right but it was my mistake because I try to read and flash with the clamp not fitted correctly but now after 10000 try I fit it and bacause I'm not able to desolder it I want to try to restore the laptop in this way. I disconnect the ch431a but not the clamp and now the laptop play some strange sounds (bip bip...) and nothing else
                        I not want to disconnect the clamp because if I have to flash another firmware I not want to make again 10000 try to fit it.
                          look around bios chipset if you didn't damage any component during 10000 tries, it happens
                            Finally I get it working again by flashing the #22 bin file...Now I have a no password bios!!! So the problem was not using 1.8v adapter
                            Thank you for your support!!
                            Just last question: why you say to restore original dump if with patched one all is ok?
                              Originally posted by Maxpower3 View Post
                              try this one to test
                              Click image for larger version Name:	chk.jpg Views:	0 Size:	231.5 KB ID:	3234910
                              Click image for larger version Name:	cks.jpg Views:	0 Size:	320.2 KB ID:	3234909
                              Click image for larger version Name:	chk2.jpg Views:	0 Size:	349.6 KB ID:	3234911
                              SIR COULD U PLEASE TELL US IN STEPS
                                Hello watch this video ...
                                https://www.youtube.com/watch?v=3BB--9VU0R0
