HP ZBook Power 15.6 inch G9 Mobile Workstation DAXW5FMBCF0 bios
    HP ZBook Power 15.6 inch G9 Mobile Workstation DAXW5FMBCF0 seri 5CD2317NFD
    clear me help me
    S.N:- 5CD2317NFD
    try
    HP ZBook Power 15.6 inch G9 Mobile Workstation DAXW5FMBCF0 S/N 5CD319GDQJ is in need of a BIOS password reset. BIOS Image attached as "ZBook Power G9 MAIN DAXW5FMBCF0.zip". I would appreciate it if you could help me out here.
    Click image for larger version  Name:	hp-sn-2.png Views:	0 Size:	167.8 KB ID:	3210396
      Originally posted by blionb View Post
      HP ZBook Power 15.6 inch G9 Mobile Workstation DAXW5FMBCF0 S/N and other info in picture below in need of a BIOS password reset. BIOS Image attached as "ZBook Power G9 MAIN DAXW5FMBCF0.zip". I would appreciate it if you could help me out here.
      ❤️Must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.❤️
      ❤️Provide the full machine model number, serial number (or Service tag, SNID)❤️
        Sorry new here. I updated the post with the serial number written down. Thank you.
          At 1st boot press F10 and RESET BIOS to factory defaults
            Worked like a charm. Thanks a lot for the help which is greatly appreciated.
              Hi, please help me rebuild & clean ME bios for HP ZBook Power 15.6 inch G9 Mobile Workstation, it doesn't show image after bios update. Or please provide MFIT 16.0.15.1662.
              MB: DAXW5FMBCF0
              SN: 5CD2331W9V
              Thank you.
                MB: DAXW5FMBCF0
                SN: 5CD2331W9V
                Thank you.
                try a clean image
                  try a clean image
                  thank you but didn't solve the problem, I will read also EC chipset maybe there is the problem and maybe you take a look. CapsLock blinks 5 times, this generally means EC has timed out waiting for the bios to POST.
                    write product id
                      Originally posted by farouk_1994 View Post
                      write product id
                      Prod uct id is : 69Q84EA#ABF
                        Try this file exracted from hp website
                          did you try it ??
                            did you try it ??
                            not yet, i have some personal business to take care of. I will provide feed-back, thank you.
                              did you try it ??
                              HI, finally I am able to work, i did try your file and doesn't work. I think is EC chipset, please take a look. Thank you.
                                MB: DAXW5FMBCF0
                                SN: 5CD2331W9V
                                Thank you.
                                Send to you, try !!
                                  Originally posted by minhdigital View Post
                                  Send to you, try !!
                                  thanks again but it doesn't work. I think your rebuild bios is ok and I have problems with EC bios. If someone can provide me EC I'll be grateful.
                                    here
                                      Originally posted by rex98 View Post
                                      here
                                      thank you, I am sure you did a good job but laptop doesn't work, with your EC it restarts 2 times, caps lock is blinking 5 times and fans spinning very fast. I let it half hour thinking is in recovery but no joy.
