BIOS for HP Laptop 15s-fq5054tu is needed
    HP Pavilion 15s-fq5054tu.
    Could anybody give a working BIOS dump for 0P5N, please?
    Once the power button is pressed, LED on board lights up for several seconds, fan spins, then both go off. Black screen.
    Hi
    Motherboard is DA0P5NMB8E0 REV: E
    Original BIOS is attached.
    The serial is 5CD2511ZVH
    CPU: SRLFR
    You MUST:
    • Read BIOS guides, methods, resources and tools
    • Try the method at BIOS guides, methods, resources and tools before requesting help
    • Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
    • Use search function in case someone already answered your request
    • Post under a related thread if it exists
    • Provide the full machine model number, serial number (or Service tag, SNID) and the board model number (see https://www.badcaps.net/forum/showthread.php?t=88758 ) ,The serial number, make, full model number, motherboard model and revision (except QR codes) must be written/typed at your request as per the rules. Not as a picture, part of the file name and so on.
    • Name your thread with make, full model numbers and request
    • Provide a BIOS/EC dump if possible
    • Attach files directly to your post instead of linking to external websites
    • Post what the problem is, be specific - black screen, no boot, running slow, password. Do NOT post "clean me", "clear bios", "clean bios", "fix bios", "bios need" or other such terms.
    "How to" guides:
    [Guide] How to extract ready for programming dump from HP update executable file
    https://www.badcaps.net/forum/showthread.php?t=121948
    https://www.badcaps.net/forum/showth...51#post1261151
    DMI: 801000 - 802FFF
    Windows key: 8A6000 - 8A603F
    Become a Badcaps supporter
    Thanks to all supporters.​
      Serial number ?
        Originally posted by hoaca388 View Post
        Serial number ?
        It's weird, I edited my first post adding serial...
          CPU: SRLFR
          HP Laptop 15s-fq5054TU (6Q0L1PA)
            [QUOTE=hoaca388;n3204132]
            HP Laptop 15s-fq5054TU (6Q0L1PA)[/QUOTE
            Appreciate your prompt help!
            Sorry could not check it earlier. I have programmed the chip with your file - no change, unfortunately. Supposedly, CPU is dead, as behavior is the same - all main powers rise for several seconds, fan spins then all goes off. No shorts on the board. Any idea if you had same situation?
              The bios I gave is the original HP bios, if it doesn't work then you have a hardware problem.
