Lenovo Thinkpad Ec Pwd Bypass
    Originally posted by Maxpower3 View Post
    This happens to me too,
    change the timing and start earlier just before backlight and stays short for less time.
    Mec16 is difficult
    many many tries
    HELLO SIR, whoever addresses you with the utmost respect is a humble follower of your work...I would like to ask for your help...it can be done on a L14 GEN 1...i5 10th...THANK YOU VERY MUCH
      Originally posted by azanwaqas771 View Post
      hi any one can onlock P15 Gen 1 NM-C651
      try
        Thinkpad L14 GEN 1 - GL40-GL5A0 NM-C631
        try
Name:	Thinkpad L14 GEN 1 - GL40-GL5A0 NM-C631.jpg
          try
          not working with stuck on logo
            Stuck when you connect EPSI IO3
            In EPSI 101 not stuck i check already.
              i connect with ESPI 101
              bro
                I check with ESPI 101 but same stuck on logo
                  Hello Sir
                  Based on the information from Maxpower3 the timing is very important
                  Tq
                    try
                    I tried to understand the image but it is too advanced for me... when I saw his video on YouTube bypass 2 minutes... where it seems that he uses a jumper by touching 2 points and breaks the bios key... I thought it could be done like this as the video... I don't know how to read schematics, I'm very new to that level...
                      I found that it has 2 bios.. I attach photos.. thinkpad L14 i5 10th bios paswoord
                        1 wire to ground on one of the points following 1 or 128/127/126 of your choice
                        at startup as indicated in previous posts
                        EC : NPCE68AP
                        L14/L15 gen1 GL40-GL5A0 NM-C631
                        of course, check that the diagram matches
                        Click image for larger version  Name:	Thinkpad L14 GEN 1 - GL40-GL5A0 NM-C631.jpg Views:	0 Size:	372.8 KB ID:	3259076
Name:	Thinkpad GL40-GL5A0 NM-C631.jpg
Name:	Thinkpad L14 GEN 1  GL40-GL5A0 NM-C631.jpg
                        Who has now used this technique and is satisfied with it here ??
                        just to give some feedback
                          EC : NPCE68AP
                          It took me a while to disassemble because the keyboard is somewhat difficult to remove... before trying anything I preferred to consult and thus have safe advice... am I going to connect the ground jumper to 128? for 3 seconds straight? or how should I do it? thank you master!
                          I leave images so that someone else can help
                            Click image for larger version  Name:	Nouveau Image bitmap.png Views:	0 Size:	6.76 MB ID:	3259195
                            Connect your motherboard to an external screen or with the original LCD, being careful.
                            Uses a USB keyboard to make things easier and avoid communication problems with the KBC(Ec)
                            Prepare a ground wire.
                            When everything is ready.
                            You must put a wire on the ground and make a light contact (1 -2 seconds should be enough).
                            If too long, errors occur : Fan error, Bad data, Thermal sensor etc ... and power off
                            Wait the Logo or just after the backlight.
                            Short contact with pin 128 or 1, wait and release
                            and press F1 to enter setup
                            After clearing security with blank password
                            and clear security chip.
                            Simply restart with Ctrl Alt Del
                            And test now
                            Warning:
                            Do not short before full startup (backlight), nor during shutdown.
                            Follow this carefully, otherwise there is a risk of bricking or corrupted data.
                              And test now
                              Warning:
                              Hello Maxpower3,
                              This Tutorial is very Awesome and everyone can used this for unlocking their laptop,
                              Thank you for sharing with us,
                              For me its very clear,
                                I couldn't enter... I touched 1 and 128 and nothing... it stays on the logo and if it is before it stays dark... use the point on the USB side and where the screw goes, which are ground and points 128 and 1 and 127 and 126 I did it many times
                                  DOES ANY NEWS ABOUT MEC 1503 FOR NM-D341
                                    Lenovo l14 gen2 nm-d271 bios password unlock??
                                      Hi
                                      Could someone help with solution for Lenovo t14 Gen1 NM-C931 Rev: 1.0
                                      thank you
                                        Originally posted by reamon View Post
                                        Hi
                                        Mec16
                                        look for j9301 if you have it
                                        https://www.badcaps.net/forum/troubl...61#post3250061
                                          NPCE68BPA0DX Lad Pin 126-127-128 or 1 of EC
