Samsung Chromebook 2 xe500c12
    Hi can you help me with a dump bios .bin file for Samsung chromebook 2 XE500C12 mb- lucas2_11b ba41-02407a that supports win 10.
    post moved..
    read...https://www.badcaps.net/forum/troubl...before-posting
    post S/N, post the bios even if it is corrupted, etc....
      Hi can anyone help me with a dump bios.bin file for Samsung chromebook 2 I want the machine supports windows 10 and not chromeOS.
      S/N:1K2Y9FCG301089D
      MODEL NO: XE500C12 mb- lucas2_11b ba41-02407
        S/N:1K2Y9FCG301089D
        you have to remove battery ( to eliminate WP), enter in developer mode and install coreboot if you want to run Win10
          Hi i have done that so many times keeps on reventing itself on this message "ChromeOS is missing or damaged. i have tried to boot back the ChromeOS into the system
          but its failing as well. When i press the Tab key to check the errors its says "No bootable kernel found on disk" I
          believe this this not the Hardware issue.
            when you have the message ""ChromeOS is missing or damaged" press Ctrl+D twice to enter in developer mode. But you have to remove battery and run only with AC Adapter.
