ASUS M712DA DMI Data
  • tom3k
    • Dec 2023
    • 10
    Hey Guys!
    Do you know where in the BIOS of the asus m712da laptop is the DMI data? I have a clean BIOS and need to copy the DMI data and windows key and don't know where to look for it.
    Motherboard: X512DA
    Thanks!
  • peste
    • 14050
    • ROMANIA
    Originally posted by tom3k
    Hey Guys!
    Motherboard: X512DA
    Thanks!
    read the rules..https://www.badcaps.net/forum/troubl...before-posting
    post the original bios, S/N, etc...
    • tom3k
      • Dec 2023
      • 10
      ASUS M712DA-AU166T
      SN: L5N0CV15F414229
      • peste
        • 14050
        • ROMANIA
        ASUS M712DA-AU166T
        SN: L5N0CV15F414229
        bios extracted from Asus site update for ASUS M712DA...try it..
        • jbonavita
          by jbonavita
          Some issues
          Things I tried
          04-29-2025, 09:38 PM
        • lrouw84
          Asus vivobook s510ua bios changed to x510un
          by lrouw84
          Hi there,
          I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
          I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
          01-28-2023, 01:31 PM
        • DynaxSC
          by DynaxSC
          06-14-2024, 03:49 PM
        • razor_amd
          by razor_amd
          12-15-2020, 07:07 PM
        • macabook
          by macabook
          🧩 Initial Issue
          07-24-2025, 02:17 PM
