need help with asus g14 2022 model GA402RJ bios
  • fallbelow
    • Jul 2024
    • 9
    • usa
    i bricked my bios using the smokeless umaf tool and trying to tighten ram timings. i purchased a ch341a programmer and made the mistake of not backing up my bios before flashing the stock bios on the chip. i tried injecting my serial and all in the bios and then flashing but now the hdd light just blinks when powering on and nothing else. ill attach the firmware i flashed to the chip and the default i added it to. also the chip is a winbond W74M25JWEIQ. my serial is N2NRKD019645059
  • Ponto da Manutenção
    • May 2024
    • 97
    • Brasil
    I believe that the CH431A does not read the Winbond W74M25JWEIQ.
    This bios is 1.8v and would need a 1.8v adapter.​
    • fallbelow
      • Jul 2024
      • 9
      • usa
      yes i have the adapter and can read and write. its just after writing the laptop wont power on now, the hdd light just blinks every 5 seconds.
      • hoaca388
        Badcaps
        • Jan 2022
        • 11700
        ROG Zephyrus G14 (2022)
        • fallbelow
          • Jul 2024
          • 9
          • usa
          I flashed the chip with this rom with asprogrammer and it still just blinks every 5 seconds on the hdd light when I plug the cord up to the board. Idk if it makes a difference but even though my model on the box says g14 GA402RJ-g14.r96700 my board says GA402RK
          • fallbelow
            • Jul 2024
            • 9
            • usa
            Any idea what could be causing the hdd light to just blink every 5 seconds? Every bios I’ve flashed to it either causes it to do nothing or causes it to blink when plugged in.
              • May 2024
              • 97
              • Brasil
              Tomorrow I'll post your original bios (ASUS_GA402RJ_319_BIOS_Update_2)👍
              • fallbelow
                • Jul 2024
                • 9
                • usa
                Thanks brother I appreciate it. Any idea on what I did wrong? For future reference. I extracted the padding from the backup and injected it into the empty padding in the default bios.
                  • May 2024
                  • 97
                  • Brasil
                  Your biggest mistake was losing your backup!
                    • May 2024
                    • 97
                    • Brasil
                    Try this file.
                    • fallbelow
                      • Jul 2024
                      • 9
                      • usa
                      Try this file.
                      I finally got around to flashing this but it still just causes the had light to blink when plugging in and trying to power on. I also noticed that pin 1 on the chip has continuity to the ground pin. Could that be causing it to not power on and blink like that?
                        • May 2024
                        • 97
                        • Brasil
                        Remove winbond, test in reverse conduction?
                        Values must be universal.
                        It's quite possible that the (ci Winbond) burned down...
                        Take care when handling the (CH431A), especially since it is a (ci Winbond 1.8v)​
                        • futadmytro
                          • Aug 2020
                          • 60
                          • Сполучені Штати
                          hello
                          pleace help, laptop did not post, possible after bios update
                          mb ga402rk ddr5x16 r2.2
                          ga402rj-g14.r96700 on sticker
                          i try flash bios from this topic but no luck
                          • peste
                            • 12737
                            • ROMANIA
                            Originally posted by futadmytro
                            hello
                            post S/N, full name and model,etc
                            • futadmytro
                              • Aug 2020
                              • 60
                              • Сполучені Штати
                              GA402RJ -G14. R96700
                              SN: N2NRKD029521089
                              CN: G0J8
                              • VektorR
                                • Oct 2024
                                • 9
                                • New Zealand
                                Hello. I have a problem with my Asus Zephyrus G14 GA402RJ. Can someone upload full decrypted BIOS dump for it with ME region please?
                                  • 20793
                                  Thread merged. Please read the rules before posting, you must post the laptop serial number - SNID or Service tag (it must be TYPED - Don`t post pictures), post in an existing topic if there is one, post your backup etc,etc -> https://www.badcaps.net/forum/troubl...before-posting
                                  • VektorR
                                    • Oct 2024
                                    • 9
                                    • New Zealand
                                    Hello. I have a problem with my Asus Zephyrus G14 GA402RJ - very delayed start, no keyboard backlight.. Can someone upload full decrypted BIOS dump for it with ME region please?
                                    S/n: N8NRKD00428234F
                                    Model: GA402RJ6800-0 EADXHB8X20
                                    CN:JHNY
                                    • danito
                                      • Jun 2016
                                      • 901
                                      CN:JHNY
                                      and bios backup?
                                      • VektorR
                                        • Oct 2024
                                        • 9
                                        • New Zealand
                                        Unfortunately there is no possibility to get corrupted BIOS backup since my laptop is with IT technician and the BIOS is corrupted anyway. That's why I asked for full backup of known good BIOS from the same model which someone might have.
                                        • throwaway327
                                          by throwaway327
                                          Model No: RC72LA
                                          Serial No: SBNVKD001014459
                                          06-18-2025, 05:52 PM
                                        • razor_amd
                                          by razor_amd
                                          12-15-2020, 07:07 PM
                                        • grimacelord
                                          by grimacelord
                                          07-10-2025, 02:52 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
                                        • lrouw84
                                          Asus vivobook s510ua bios changed to x510un
                                          by lrouw84
                                          Hi there,
                                          I know there is somebody who can tell me what is happening with my laptop. For start, it is an asus vivobook s510ua with an asustek x510ua motherboard with an intel i5 7200u cpu and 16gb ram.. i have a screenshot from speccy before strange things started.. as you can see the laptop type and bios version x510ua.302.I don’t manually update the bios because i don’t like to having a bricked bios, i know what troubles that gives..
                                          I did a fresh win 11 install, and after the automatic updates, windows rebooted and automatically started asus ez flash.....
                                          01-28-2023, 01:31 PM
