Asus S533E bios Password
    Bios Dear all, Please I need to remove bios password from this dump. I tried the but no power on. Please help thanksClick image for larger version
    dump
      Originally posted by Pascoalcaz View Post
      dump
      Serial number ?
      Become a Badcaps supporter
      Thanks to all supporters.
        Pascoalcaz try this bios UNLOCKED . and tell me if work for you...
        turns on but no LCD signal
          Originally posted by hoaca388 View Post
          Serial number ?
          here it is
            here it is
            My eyesight is bad, can you write it down ?
              S.N M4N0CV17H55817D
              X521E0
              69N1BM13C51
              S.N M4N0CV17H55817D
              X521E0
              69N1BM13C51
              X521EQ
                X521EQ
                IT DOESN'T TURN ON WHEN I CLICK ON THE POWER THE LED FLASHES AND WHEN I TRY TO CLICK ON THE POWER AGAIN THE LED NO LONGER FLASHES
                  Reflash the original file and see if it works.
                    Thank you for your patience
                      I TESTED THE POSTED DUMP AND REALIZED IT WAS CORRUPT AS I HAVE MADE TWO BACKUPS I TESTED THIS ATTACHED DUMP IT WORKS PLEASE HELP ME WITH UNLOCKING THIS DUMP
                        You have not answered my question.
Name:	2024-08-15 20_23_54-Asus S533E bios Password - Badcaps.png
                          THE ORIGINAL FILE WORKS I TRIED TO MODIFY IT AND IT STILL DOESN'T WORK
                            If you don't have any hardware errors then the file in #9 should work.
                              original that first one I posted doesn't work but this dump does please help me with this
                                Ok. I hope you are right.
                                  IT WORKED BUT IT DOES NOT RECOGNIZE THE MOUSE AND THE SSD
                                    SMDFlea commented
                                    Editing a comment
                                    Is there something wrong with your caps lock key, please post in lower case ,not UPPER CASE
                                  Thank you very much everyone Here is the corrected and working bios
