HP spectre x360-13-4126na (ENERGY STAR)
    Hi can I have a dump file please for a HP SPECTRE x360-13-4126na(ENERGY STAR Serial number:5CD6377BND
    Ive tried these thinking they could work but they are for an hp spectre x360 13-4129na i was trying to fix any more help would be great thanks
      post the original bios of the laptop even if it is corrupted
        Hi buddy ive Attached the bad bios file if i can get a good bios dump and it still doesnt work then i can start to look at harware issues thanks again for all your help
          you have everything you need at post #17.. your bios is 0804F
          https://www.badcaps.net/forum/troubl...p-lock-no-post
            Ill give it another go i think thats the same file i used for my other model hp spectre x360 13-4129na thanks again bud
              Try this one..
                Thank you I'll give it ago later tonight 👍
                  i wonder if i have a fault with the programmer the issue started when i was reading a good bios image im using a EZP2023+ im thinking the RT809F ISP Programmer is a better option to try all the images again
                    yes. possibly..
                      ill try both later buddy and ill order the RT809F ISP Programmer now and ill post the results thanks again for your help
                        Before i jump in can someone recommend a good bios programmer thats better than the EZP2023+ i heard the EZP023+ has a 5v data issue that could be affecting the chip programming thanks again for all your help
                          is this a better programmer the Universal XGecu T48 or this one RT809F or any other suggestions please id rather not use my EZP2023+ think its faulty
                            Svod 4 👍
                              That ones a wee bit to expensive buddy thanks anyway bud
