here
quanta R53 bios dump hp g6
Re: quanta R53 bios dump hp g6
Originally posted by dycc View Posthere
God bless you!
Today I fixed the Bios Memory with External SPI FLASH MEMORY!
I have a HP pavilion G6 2105sa with motherboard serial R53!
The problem is : black screen is appear when I press the power button, The dedicated video chipset is not present on this motherboard and after I assumed that bios memory is corrupt!
I searched some days and I could`t find nowhere! I wrote only "bios R53 hp" an I found your .bin file!
Tnx dude you are my save!
Hi
Yes when you download the update it needs to be unpacked look for the .fd ending open it with a text editor and compare with the original file if the file don't look alike then it's decryped and you need to run it threw a phoenix program in which it will leave you with a folder.. look for a BIO0 file now it's no longer decryped go back and compare with the original file if all looks good ending match now it's ready . If ending are different then you are trying to use the wrong file or version. then on HP you will need to run the DMI tool to serial # ,Make model and so on ..only other way if you know where to cut it out of original file and past this info in new bios will also work .. if you never done it it will take some practice or just upload it i will do for you.
Techman1025
