Lenovo L14 gen 2 unlock with svod4
  • x16
    • May 2015
    • 85
    I have a problem with a Lenovo L14 gen 2 (intel) with Nuvoton npce68b.
    I connected my svod4 with a 32pin cable to the keyboard connector. Ground is also connected and power for the mainboard. I can read the Nuvoton ID, but the dump is always empty. Does anyone have an idea?
  • Maxpower3
    Bad Veteran
    • Feb 2018
    • 1248
    • France
    This one works in bypass, right?
    https://www.badcaps.net/forum/troubl...86#post3217086
    https://www.badcaps.net/forum/troubl...45#post3263045
    • x16
      • May 2015
      • 85
      Thank you, but i already read the both threads yesterday. And i tried bypassing method 4 hours. But didn't work. I tried shorting Pin 26, 27, 28 or 1 shorting to ground. I tried on backlight on at the moment when Logo apears. Nothing! If i short too long or at wrong timinig it freezes, but never got error like fan error or something.
      • Maxpower3
        Bad Veteran
        • Feb 2018
        • 1248
        • France
        probably a writing error
        126-127-128 or 1
        intel too, amd works more easily. wait for someone else's response to see if it succeeded.
        it was to see if you had the info
        11th gen ?? Espi this one, don't try the bypass in this case
        what is the ref​
        • x16
          • May 2015
          • 85
          Yes sorry it was 126, 127, 128 or 1
          And thank you for the links.
          General:
          I normally unlock mec16xx chips with the SVOD4. I have little experience with Nuvoton. Am I perhaps doing something wrong? Do I have to solder a resistor? Because I can read the Nuvoton ID, but neither the content nor can I delete the chip.
          EDIT:
          It works now. The trick is, only connect a (better full charged) battery. Do not connect usb-c power.
          • coasterghost
            Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
            by coasterghost
            For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
            Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
            Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
            System Hardware:
            Processor: AMD Ryzen 7 PRO 5850U
            Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
            09-08-2025, 10:46 PM
          • esolks
            Lenovo thinkcentre M70q Gen 2 advanced menu unlock
            by esolks
            Hello to all
            i have a lenovo m70q gen 2 , i need to unlock hiden advanced menus to configure tdp ( i'am using currently an i7 10700 ( non T ) and need to customize PL1 and PL2 )
            can someone please help me ?
            best regards...
            07-11-2025, 05:03 AM
          • aaroncm
            No video when trying to unlock Lenovo T420
            by aaroncm
            Hi guys,
            Today I pulled 5 Lenovo T420 laptops out of a bin at the rubbish tip, and they're old school laptops and they're all locked with a supervisor password.
            In the past I've unlocked similar Lenovo laptops, often I used the trick of shorting a few pins together on the chip on boot to get into the GUI and overwrite the config but it doesn't look like that is working with these laptops. I guess Lenovo fixed that trick? I have unlocked some other HP laptops by reading the chip, running a patch and re-writing back.
            But I can't work out these T420...
            11-11-2023, 10:05 AM
          • shiriff47
            Need help to unlock Lenovo 100w Gen 4 bios
            by shiriff47
            Please i need help to unlock lenovo 100w Gen 4
            Mfg date : 202/06/17
            S/N : PW06GSWW
            MTM : 82VLS01G00
            MO : PW90B3618007
            this is my bios backup...
            06-13-2024, 04:30 AM
            Lenovo 3000 Series Schematic
            Lenovo 3000 was a line of low-priced notebook and desktop computers designed by Lenovo Group targeting small businesses and individuals. It was replaced with the IdeaCentre and IdeaPad brands.
            3000 C100 laptop with Braille keyboard
            Lenovo 3000 C
            C100, C200 - 15-inch XGA screen
            Lenovo 3000 N
            N100, N200 - 14.1-inch- and 15.4-inch- WXGA models
            N500 - 15.4 inch screen.
            Lenovo 3000 V
            V100, V200 - 12.1-inch WXGA models
            Lenovo 3000 G
            G400, G410, G430, G450, G455, G510, G530, G550, and G560...
            10-04-2024, 06:05 AM
