Samsung NP300E5C bios dump needed
    I m looking for a BIOS dump file for NP300E5C,
    thanks in advance
    Re: Samsung NP300E5C bios dump needed
    Here
      you guys are great ! thank you so much
        Originally posted by cyberhack View Post
        Here
        thanks i will test, my machine have that famous bios brick from this machines.
        stuck in bios logo loop.
          update ----
          this bios is for np300e5x and not for np300e5c, there are some difference, missing secure boot. i will post the correct one.
          the machine still work and post with this one, but i prefer to load the correct one.
          Marca -samsung
          Modelo -NP300E5C
          Board -Scala3-15/17CRV
          Bios -P03RAQ
          https://www.badcaps.net/forum/attach...1&d=1405354294
            thank you so much for bios file
              Here
              Thank you so much its worked well
                thank you very much very helpful
                  How do we install/update the bios using the file provided?
                  I would like to do the bios update using a USB stick as I can not boot into windows.
                  Any help would be greatly appreciated.
                    My np300e5c will not recognize my hard drive and I tested the drive in another computer and it is good. The hard drive is not detected by the laptop properly and i think this may be the solution.
                      Originally posted by kukasIII View Post
                      update ----
                      Marca -samsung
                      Modelo -NP300E5C
                      Bios -P03RAQ
                      How to flash?? anyone???
                      FatherOf~5ive
                        thanks
                          Here
                          thank you very much
                            thx dud!
                              hey mate , welcome to the forum , don't forget to real our rules for the best of the forum.
                              About flashing , you will require a Flasher , for EX MINIPRO TL866CS
                              with this device , you simple need to remove the rom file of your board , and insert it on this device , further than you must get rom files to update your bios .
                              usually to find rom files , or you can chek it here or online on google , or you can get them at the regular laptop brand , toshiba , hp etc etc , but usually they are more hard to use , since they need to be cut , etc etc .
                              Well but stick around , and you'll see how things work around here.
                              best of luck
                                thank you !
                                  Hi...
                                  Thank you very much very helpful
                                  I program the bios with this dump. And work finee...
                                    Here
                                    i used it my self, 100% workig
                                      10q! Burn it and work like a charm!
                                      10x again!
                                      JJ
                                        thank you !
