Toshiba C50-a628 BIOS need.
    Hi brother, I need toshiba c50-a628 bios. Because this bios only support UEFI boot. So i need update bios for CSM boot. i have downloaded toshiba server but this bios is more than 8MB so that i cant use it.
    System model: C50-A628
    Part no: PSCJGV
    Motherboard PN: DB10BM-6050a2623101-mb-a02
    If anyone can please help me.
    Thanks advance
    I have attacched orginal bios below.
    Re: Toshiba C50-a628 BIOS need.
    you can change uefi boot but you need to disable some security settings so you can install hdd
      install windows 8 first, update the new bios with csm , then install windows 7.
      i had the same problem
        Part no: PSCJGV
        Thanks advance
        Just enable Legacy mode, to install windows 7. use flash drive w/ win7 installed in it, hit F12, select your flash drive name from the menu then hit enter.
          This bios only support uefi mode and I can't boot windows 8 also.when I boot from pendrive or windows 8 dvd it gives this message ``checking media failed``Or tell me how can I update this bios. Waiting for good solution. Thanks again.
            use rufus to create uefi bootable usb installation diskof win 8, works 100%
            and for the sake of testing try this bios, make sure you have old backup, i have no laptop to test it, dunno will it work
            Im Back... sort of...
              Thanks I will check tomorrow and let's you know.
                Thanks ala_borbe, i have tried with your bios but its not power up my laptop. also try with rufus to make bootable pendrive but also same no bootable media found. Please give another bios file.
                  try this bios
                  this is tutorial on how to use rufus
                  Code:
                  http://www.nextofwindows.com/how-to-make-uefi-bootable-usb-flash-drive-to-install-windows-8/
                  maybe you don't have uefi win8, some installation discs do not have uefi files on them, so they cannot be booted on uefi environment
                  if so, you need new win8 installation iso
                  you can also try downloading iso bios update for this model
                  Code:
                  http://support1.toshiba-tro.de/tedd-files2/0/bios-20140402102034.zip
                    Thankss lot all off of you speacially ala_borbe. I have updated bios with your provided ISO image. By the way i want your help , Can you give your e mail id to me?
                      ok, no problem, im glad it worked
                      mail *****************] but you can contact me here, via pm or so
                      anyway, would it be to much to ask you to once again dump your new bios so that it might help others and to see what i did wrong and why my dump did not work?
                      tnx in advanced
                        Your second uploaded dump also no power, I have upload my working dump below.
                          Thanks for uploading bios. its works. Thanks lot
                            thanks a lot, fix my problem too!!!,,
                              Teste on a C55-A-1U3, it worked well! Thanks
                                Thank
                                  greatt
                                    it work for me , thank you
                                      working, Thank you
                                        Originally posted by ajbernasko
                                        need bios for Toshiba Satellite Pro C50-H-11B board number is IP3_IN16_MB_V30_20201105A
                                        This thread topic is for the C50-a628 .Start your own thread...
