Dell p28f 3537 LA-9982P bios need
    Re: Dell p28f 3537 LA-9982P bios need
    can you upload your BIOS dump?
      save your bios and use attached one.
        here
        Im Back... sort of...
          Thanx.i try then i report u
            Originally posted by ala_borbe View Post
            here
            thank you for bios
              thanks............thanks A lot.......
                is inspiron 5537 Also refer the same bios?????????
                  thank you so much
                    Cheers thanks a lot for sharing:-)
                      thanks friends
                        thanks
                          this is the schematic
                            thanks very much
                              thanks
                                V good help
                                  hey guys,
                                  can any one tell me what should be +VCHGR. Or how much volt should be on pl701 ?
                                  m having 13.5v.
                                  thanks in advance.
                                    Originally posted by abbas_govani View Post
                                    hey guys,
                                    m having 13.5v.
                                    thanks in advance.
                                    if your battery is connected then its depend on your battery voltage..and the charging voltage be continuously rising on multimeter if your charging section is ok....and if your battery is not connected it may be 2 or 3 volatge showing.
                                      thanks bro
                                        Thanks soo much.
