Sony VPCEB1E0E (PCG-71312M) BIOS
    Hi
    I have a Sony Vaio VPCEB1E0E (PCG-71312M) with a strange issue.
    The laptop turns on and start loading but after about 20 seconds the fan starts spinning as full speed and then it shuts off. It even shuts off when the HDD is removed and left for 20 seconds in the BIOS setup.
    I already replaced the BD82HM55 SLGZS chip but issue persists.
    Reflashed BIOS from online dumps did not help either.
    Any clues please?
    BIOS info:
    BIOS version: R0300Y8
    EC version: K0300Y8
    ME version: 6.0.3.1195
    Motherboard info:
    Motherboard: MBX-223 M960 (1P-009CJ01-6011)
    Chipset: BD82HM55 SLGZS
    EC: Nuvoton NPCE783LA0DX
    Re: Sony VPCEB1E0E (PCG-71312M)
    Update - Programmed the Flash with a dump found online and now it powers and DOES NOT shut off after a few seconds.
    However the fan control is intermittent. Sometimes it does not spin at all (even at very high temp) and sometimes goes full speed.
    When the fan is off the PWM signal is low on the EC and when on the signal is 5v.
    Any clues? Maybe the EC is faulty?
      can you attach the bios file here?
        Yes sure, please see below:
        https://dl.dropboxusercontent.com/u/...pc-ea%20eb.rar
          Update: Success!
          It took me 3 days non stop to fix this issue. It was software related after all.
          After changing a BD82HM55 chip, then the BIOS (dump) needs to be modified with a CLEAN ME firmware.
          I used Flash Image Tool: 6.0.40.1212 to inject the CLEAN ME firmware to my original dump.
          After several attempts it worked.
          Please follow link below to download the modified and working firmware. Please note that this is only suitable for Sony VAIO VPC EA/EB series.
          If you have the same issue on another platform, I will then provide more details on how to do it.
          https://dl.dropboxusercontent.com/u/...mage_clean.bin
            I have read your thread and unfortunately, the link is outdated.(logical). I have the same issue with a vceb2s1e. The only way to get the fan quit, is to use afuwinx64 in a dos window. Until you restart the laptop and it will be on full speed again. You can't keep flashing every time.
            This indicates that it is something with the bios, but I tried many different versions and the next time it starts up, the fan is at full speed again. Strange.
            I would appreciate some help.
            thx
              Please use this one:
                Thanks a lot.
                Sorry I want to be sure how to flash this file, pls advise
                  Originally posted by bicalov View Post
                  Thanks a lot.
                  I use an SPI EEPROM programmer. It can be done through command line as well but not sure how.
                  Can anyone help please? Thanks
                    I tried different ways with Afuwin and FWupdate but no luck.
                    I do have the CH341A programmer, but I used that already on other eeproms
                    and that didn't go well. The programming in reading and writing went normal, the chip was recognized but the chip didn't work anymore after that. I flashed the wrong bios.bin or I did something wrong with the CH341A
                      "Solved" the fan problem. I have been busy with Aduwin, Fwupdate, ME flash tools and tried them with different bios version. I have a combo now from R0300Y8 with K0230Y8 and I know this is not correct, but it works. Therefor the "solved" Enough time went in this fan problem.
                      Kevspit, thanks for the help and advise.
                        to bicalov:
                        hello, how you reach, bios and EC version is difference?i have fan problem too. thanx for you advice.
                          i can download file please
                            hi can you please re upload the clean bin for this model we have same problem
                              Try these, Flash bios and 8 pin EC.
                                Thanks bother this dumps working perfect
                                  thanks bro.
                                    Re: Sony VPCEB1E0E (PCG-71312M) BIOS
                                    any one have this model bios vpceb46fg
