Originally posted by dikmen
View Post
dell vostro 3500 bios dump needed
Become a Badcaps supporter
Thanks to all supporters.
model: dell vostro 3500
reg type no p90f005
mb:gdi4 la-k032p rev:1.0
servis tag:f76mfd3
My device does not start with the original bios. When I sent it before, I was told that the bios was corrupted.
My device turned on with the bios I sent, but the service tag. I can't change it, it opens with an alt+f warning every time I open it.
Please service tag. help me fix it
model: dell vostro 3500reg type no p90f005mb:gdi4 la-k032p rev:1.0servis tag:f76mfd3
The original bios of the notebook is corrupt, it started with the bios I sent, everything is working normally, but I could not install the original service tag and the fan is running high at every startup and it gives the alt+F warning.Please help me save the original service tagAttached Files
Originally posted by ava123 View PostHello!
Please help me remove this bios password.
Dell Vostro 3500
Service Tag: 50V22D3
Express Service Code: 10936076151
Board model: GDI4A LA-K032P Rev:1.0 (A00)
Thanks!
Thanks for moving my post here and i apologize for my mistake!
My code suffix is 0001.
8FC8 Patcher software works for this suffix too?
When patching the 8mb bin file, the patcher gives me this error "wa nakita ang unang pattern" (did not see the first pattern).
Patching the 16mb bin file is not working.
Originally posted by kalilinux25 View Post
Fresh from WEBSITE , CLEAN ME REGION , DMI added, please give feedback
If anyone can help me removing the bios password from my bin files i would be grateful.
Hello
my laptop stopped turning on.
I saved the damaged dump "old64 and old128" and flashed the working dump that I downloaded from the previous posts "Vostro 3500_FT6BSD3(1) and Vostro 3500_FT6BSD3(2)", after which the laptop started working correctly, but constantly gives the error "manufacturing mode active" and the coolers work at full power. If press alt + F before loading the OS, or FN + X the coolers work correctly. However, after restarting the same problem again.
Please help disable "manufacturing mode".
Vostro 3500 LA-K034P I5-1135G7
ST: 4L3RPH3Attached Files
Originally posted by Markus1741 View PostHello you can try this new files i build from your original BIOS me be it helps you.
I downloaded the BIOS recovery file from the official Dell website (BIOS_IMG.rcv), the laptop tries to read the file from the flash drive (the LED reading indicator on the flash drive blinks), but the BIOS is not restored.
Hello! I found a board for my laptop that had a faulty 16 MB chip on it. I downloaded the BIOS from the Dell website and flashed it.
The laptop is working, but after entering the service tag, I'm stuck in Manufacturing Mode. Alt +F does not help. Can you help me?
Model: Dell Vostro 3500
Motherboard: GDI4A LA-K034P Rev: 1.0 (A00)
Service Tag: FNPQ7F3
I would be grateful for any member than can help. Thank you!Attached Files
Originally posted by gaponov-o@mail.ru View PostHello! I found a board for my laptop that had a faulty 16 MB chip on it. I downloaded the BIOS from the Dell website and flashed it.
