Asus VivoBook S301LA No Power - BIOS DUMP
    i got this nice Asus with no power/lights problem.
    It's on Windows 8.1, it's possible to flash this bios like we do with Win 7 ?
    I got the bios on asus site, but there is no extension on the file, it's called only "S301LAAS.214" with 6,146Kb.
    If not, maybe someone can supply a working bios dump ?
    Re: Asus VivoBook S301LA No Power
    No one ?
    I guess that I need to open a new Thread asking for a Bios Dump !
      i`m sure that like me , all read this topic, but i only find the bios dump on vlab.ru , but i cannot download it.
        I just dumped the bios chip, and of course the size is 8mb, the bios available on Asus is 6Mb !
        Maybe someone with skills can transfer the info's from the original to the public one ?
          post your dump, i will help... no prob bro
          Im Back... sort of...
            I made a post on this site, and a guy posted a dump, i just try it, but still no change, here the link : https://yadi.sk/d/IWDqAzBVjrwEd
            But i don't know if this dump is the good one for my mobo ...
            Great buddy, you are very kind !
            Here my dump : https://mega.nz/#!mVFThZgI!0VrXfDDd5...fjbGLVUg_O36JE
            Thank you
              ok, here is your dump fixed, test and report back
                Unfortunately there is no change, when i press power, nothing happens !
                This must be a fet or a cheap component that died, cause i don't get any voltage on te bios chip.
                Thank you bro @ala_borbe for your time !
                  you talk about how ppl can`t help you and for some reason you fail to show us some pictures and what you measure and what you tested.
                  any liquid dmg, did yo change the charging port? where are the voltage stoping.
                  some QFC CHIP ( charging ic) .
                  i found a short with ground reference ( i need to trace it and see what`s there)
                  but first its the picture. You FAIL, NOT TO BOTHER and let me or other tech guys here to fraking find it on google you motherboard and deduce whats wrong with you tablet.
                  and give you a possible ASW.
                  you're a mean little man!
                  GOOD LUCK and best of LUCK with you tablet.
                    Do i Know you M8 ?
                    Maybe you use other nick on other forums ?
                    This is not a tablet, and there is no liquid spill or whatsoever !
                    I have 19V on some points on the mobo, I bet the connector is good, no ?
                    For what do you need photos ?
                    GOOD LUCK to you too !
                      thank you
                          i need ASUS S301L bin file
                            working 100%
                              thanks
                              its working
                              it takes a few seconds to boost and show up.
                                thank u
                                  Gracias 100% funcionando
                                    thank
                                      Re: Asus VivoBook S301LA No Power - BIOS DUMP
                                      Hi, Gents
                                      Looking for a ASUS X705MA BIOS - my original was Protected with password.
                                      should i load it up here ? Can any one help ?
                                        Originally posted by Jack_o_neal67 View Post
                                        Hi, Gents
                                        make a new thread in the 'bios requests only' section and post there, the bios backup ...
