hp folio 9470m
    Re: hp folio 9470m
    Hi can i pls get a working bios file for my Hp folio 9470m # board number 6050A2514101-mb-A03 bios bin
      Re: hp folio 9470m
      post the original bios even if it is corrupted..
        Re: hp folio 9470m
        100% it works nicely
          Re: hp folio 9470m
          Originally posted by imranromi View Post
          6050a2514101-mb folio 9470m
          working 100% ok check bios.
          thank u bro .work for me
            thanks
              Re: hp folio 9470m
              Thanks, confirmed working.
                Hi, I have an bios password HP Folio 9470M also with the previous owners "property of" notice at boot which I need removing. This is the bios dump. Thank you.
                  post the S/N, the motherboard model, etc.
                    S/N: CNU4059VSL
                    Motherboard part number: 717844-601
                      try
                        Originally posted by skazide View Post
                        try
                        This is constantly not writing correctly? I even replaced the chip and used a different programming tool? Any ideas?
                            Please I don't know or understand how to use any of the guides or tools like RCUnlocker ..
                            which gives me "MISSING UNLOCKABLE CONTENT" when i drag and drop the 68IBD.BIN file
                            I required help to reset / remove the BIOS pass word on my old HP EliteBook 9470m laptop
                            Laptop - serial : CNU32990FJ --- Motherboard part number: 702849-601 ( i think)
                            It's has been years since I have needed to enter the BIOS but I need to change the settings so my newer RAM can run at 1600 mhz instead of 800 mhz.
                            I have already tried the method of removing the CMOS battery etc or getting the laptop serial number in windows and then going to the (bios- pw. org) website to get the reset code but this code doesn't work for me.
                            My bios is on a BIOS chip and needs a physical EEPROM reader or a BIOS BIN file reader program. I do not have the technical skills to remove the bios chip/read it/flash it/re install it or the program to read the BIOS BIN file.
                            I know there is a way you can ask HP to send you an "SMC. bin" file from HP which you can use on an USB and boot from BUT they are impossible to reach, deal with and explain that you need that tool/file to do it yourself.
                            SO
                            If upload/send my current BIOS "file. BIN" ... can someone to check with their BIOS reader and let me know the pass word? Please can anyone help?
                            I think the moderator has helped me and my current BIOS file should be in a zip file now below. thank you
                              Hello everyone!
                              peste are you helping to create a correct BIN file for this HP model? (HP Elitebook Folio 9470m) , in affirmative case, which information is required to create one?
                              Regards!!!
                              Atte. jcdelvalle
                                post the S/N, the original bios of the laptop, the motherboard model, etc,read the forum rules .
                                  I need help in cleaning my bios
                                  the fan is blowing but no display on the screen , i have tried some of the uploaded files on the forum but non worked
                                  hp folio 9470m
                                  board number 6050A2569401 -MB- A01
                                    hp folio 9470m
                                    post the S/N,etc..
                                      hp folio 9470m
                                      Serial CNU304B7XR (This motherboard have been replaced before.)
                                      Product C6Z63UT#ABA#
                                        hp folio 9470m
                                        HI try
                                          Originally posted by shiyab View Post
                                          HI try
                                          I tried it but did not work 😭😭😭 , thanks for your help , i will inform the customer to replace the motherboard
