Dell latitude e7240
    Re: Dell latitude e7240
    Originally posted by SMDFlea View Post
    BIOS guides, methods, resources and tools
    https://www.badcaps.net/forum/showthread.php?t=103526
    3. Password removal by laptop brand
    3.4. Dell
    Thanks for your reply. I tried several times but couldn't succeed. Simple enter, control+enter.
    Can you please generate and share
      Service tag is 462BJC2-E7A8
        US layout keyboard is essential.
        Become a Badcaps supporter
        Thanks to all supporters.
          Kindly please help in repair BIOS 64bit. 32bit file is checked and proper one.
          I already tried clean ME but not worked. It just turn on withour 3 restarts.
          On other bios with clean ME it starts, so the only issue is BIOS.
          Dell Lattitude E7240
          Board Code: VAZ50 LA-9431P REV 1.0 (A00)
          sticker with service tag is damaged, it is not visible.
          on other bios i check there is i5-4300U.
          recovery of ST will be an aditional advantage.
          seems no CD-KEY for Windows.
          Thank you
            Anyone could help?
              Originally posted by rbvndonh View Post
              Anyone could help?
              Send to you
                Sorry, but this is bioa with my service tag or elswhere available bios? Thanks
                how to find my service tag?
                  SMDFlea commented
                  Editing a comment
                  The service tag in the bios you posted is GJK6TZ1 .It should match with the service tag number on the base sticker
                #48
                I have a Dell e7240 with a motherboard from ebay. When is booting I am getting "FW status recovery Error" but that's not an issue.
                From time to time, Laptop is freezing while booting and that's annoying .
                I've tried to downgrade/upgrading the Bios, but still same symptoms. While upgrading/downgrading Bios version, I could see some messages, which indicates laptop would not being able to properly upgrade "ME firmware end-up ..."
                I've tried to read the Bios from the two chips but not sure what to select from the manufacture list for 25q064A 25q03513 . I am using T48 Programmer and doesn't have the auto-detect option, and with CH341 with auto-detect option was showing XMC as a manufacture.
                MB version LA-9431P
                Service tag 7396M12
                Please advise what is the manufacture options for 25q064A 25q03513 IC, and a piece of advice if writing a new BIOS on those will fix the issues ( "FW status recovery Error" and freezing screen )
                Thanks in advance
                  MB version LA-9431P
                  Service tag 7396M12
                  Thanks in advance
                  Click image for larger version  Name:	IMG_20221117_100612.jpg Views:	0 Size:	806.9 KB ID:	3524191
                  This's bios chips.
                    This's bios chips.
                    Thanks hoaca388,
                    I was able to identify the chips on the motherboard but my question was what to choose when I am selecting the IC inside the programmer (TL48 ) for 25q064A and 25q03213.
                    CH341 with auto-detect option was showing XMC as a manufacture for 25q03213.
                      Eventual I've read the 25q064A and 25q03213 ICs using CH341 where identify the chips as being XMC (XM25QH16B and XM25QH80B)
                      TL48programmer is not able to recognize the chips and not able to read those either I am choosing Micron or XMC from list.
                      Attached the bin files below. Please remove the FW status recovery Error
                      DELL e 7240
                      MB version LA-9431P
                      Service tag 7396M12
                        DELL e 7240
                        MB version LA-9431P
                        Service tag 7396M12
                        Latitude E7240 Ultrabook
                        Service Tag: 7396M12
                          Thanks Hoaca388, did worked
                          Dont have the Error while booting.
                          Hope will fix the freezing image issues which were there from time to time
                            bios .
                            Thanks bro, working
