need bios dump .....mobo num is 820-00165-02.........
apple macbook air A1466 EMC 2926
Re: apple macbook air A1466 EMC 2926
if you need password removal post bios here
or try this repo
https://ghostlyhaks.com/downloads/efi-repositoryIm Back... sort of...
try this
do clear nvram
Resetting NVRAM
Shut down your Mac.
Locate the following keys on the keyboard: Command (⌘), Option, P, and R.
Turn on your Mac.
Press and hold the Command-Option-P-R keys immediately after you hear the startup sound.
Hold these keys until the computer restarts and you hear the startup sound for a second time.
Release the keys.
After resetting NVRAM, you may need to reconfigure settings for speaker volume, screen resolution, startup disk selection, and time zone information.
If issues related to these features continue on a desktop Mac (like an iMac, Mac mini or Mac Pro), its logic board battery may need to be replaced. The logic board battery on desktop computers helps retain NVRAM settings when your Mac is unplugged. You can take your Mac to an Apple Store or Apple Authorized Service Provider to replace the battery on the logic board.
pin thing is os problem, not bios problemAttached FilesLast edited by ala_borbe; 03-15-2016, 02:51 AM.Im Back... sort of...
Originally posted by tanveer920 View Postcan help any body???????
1. after you flashing with this file...before power on for the first time, remove your ssd first..
2. do NVRAM clear... Shut down your macbook, then turn it on and immediately hold down these four keys together: Option, Command, P, and R.
this nvram clearing to avoiding Macair drive lock feature....
3. after that you can recovery your macair using your usb , dont use internet recovery..
goodluckAttached Files
