dell E6530 LA-7761P bios
    need bios dump mobo num is:QALAO LA-7761P REv :1
    Re: dell E6530
    need this bios
      Re: dell E6530
      any body got file....
        Re: dell E6530
        here is your file .
          E6530 LA-7761p Bios and Ec file needed
          Hy, I am looking for a E6530 LA-7761p Bios and Ec. Thanks
            Re: E6530 LA-7761p Bios and Ec file needed
            Here you go and report please
                Re: dell E6530
                hi bro i need bios dump of
                DELL LATITUDE E6530 LA-7762P REV 1.0
                THANKS ALOT
                  Working dump, no password, ver A02
                    Re: dell E6530
                    Originally posted by ridamouh159 View Post
                    here is your file .
                    think you
                      Big thank you to you for me it worked
                        Re: dell E6530 LA-7761P bios
                          Thanks, BIOS sorted!
                            thank you
                            Mohammed Mohan
                              Working) Thanks a lot
                                Hello - I used these 2 files for an e6530 discrete which had no display. It works fine, but I cannot update past A02. I even tried A03 from Windows as well as USB and it will not update. Anyone have any ideas? I am not looking forward to taking it all apart again. I will post my original dumps. Thanks in advance.
                                  Does anyone have a newer BIOS dump for this model?
                                    Latest BIOS version available - A22:
                                    Become a Badcaps supporter
                                    Thanks to all supporters.​
                                      Thank you very much. That worked perfectly. After flashing those, I was able to run the Dell Bios update from Windows and clear the missing manifest. If it helps anyone, I was able to use the clip without removing the chips from the mainboard.
                                        You're welcome.
                                        Please consider donation in support of the "Bios requests" sub-section.
