samsung NP300E5X BIOS
  • kadi144
    • Aug 2015
    • 690
    • algerie
    Hi all members
    i seek a dump for samsung NP300E5X
    thanks in advance
  • rioreno
    • Feb 2009
    • 540
    • Indonesia
    Re: samsung NP300E5X BIOS
    Originally posted by kadi144
    Hi all members
    thanks in advance
    try this
    • sadboyalex
      • Jan 2017
      • india
      thanks.lets check for my np-300e5x-s01in
      • shomi75
        • Mar 2011
        • 7
        • Serbia
        Thanks. Works on np300e5x-a03rs
        • rasanansa
          • Mar 2020
          • Italy
          Thanks, but how do I flash this NP300E5X dump?
          What tool or software do I use?
          • Claudiomfa
            • Nov 2015
            • 455
            • Portugal
            you need a SPI programmer like tl866 or rt809h or ch341a with soic8 clip
            • peste
              • 12593
              • ROMANIA
              you must buy a ch341a programmer.
              • rasanansa
                • Mar 2020
                • Italy
                Maybe I asked the wrong questio.
                I have found "25q64bsig.bin" for my np3005x.
                How do i update the bios.
                what procedure and with what software.
                thanks
                • Claudiomfa
                  • Nov 2015
                  • 455
                  • Portugal
                  thanks
                  You need to unsolder chip from motherboard and write them with external programmer.
                  • rasanansa
                    • Mar 2020
                    • Italy
                    well i am not of this technical level.
                    After installing an SSD, F2 does not boot into cmos on my np3005x anymore.
                    Boot into Bios in Windows 10 option does not show.
                    Tried by removing ssd and cmos battery……..same problem.
                    i thought a simple bios update could solve the issue.
                    • aysuhcool
                      • Mar 2021
                      • India
                      Originally posted by rioreno
                      try this
                      What is Bios model no. I don't see any model no written on the bios for np300e5x. Please help
                      • toufik sat
                        • Feb 2016
                        • 134
                        • los angles
                        thanks
                        • hat7et
                          • Aug 2021
                          • Egypt
                          working very good thanks a lot.
                          • babahanini07
                            • Jan 2022
                            • algeria
                            Thik you a lot.
                            • yurasja
                              • Jul 2022
                              • Ukraine
                              Thnx !!! I`m happy !
                              • Habble7
                                by Habble7
                                Suspected Cause:
                                Troubleshooting Attempts:
                                05-22-2025, 07:28 AM
                                by Vesko356
                                08-11-2023, 03:27 AM
                                09-07-2024, 05:50 AM
                              • TJ65
                                Samsung Galaxy Tabpro S BIOS and Micom Version doesn't match
                                by TJ65
                                i made out of two broken Samsung Galaxy Tabpro S one that works partially.
                                The one Mainboard had a broken screen output but working hdmi (usb c adapter) output and the other didnt start at all.
                                I switch the bios chips and now the tablet starts but very very slow and it takes some trys to get it starting.
                                The problem is, that the micom Version doesn't match with the bios version, see picture.
                                How can i update the Micom Version? The Samsung bios update wont work.
                                With https://github.com/tavinus/SamsungBIOSTools i could extract the newest bios update...
                                01-09-2025, 01:35 PM
                              • zenius
                                by zenius
                                12-08-2024, 06:13 AM
