Dell Latitude E6540 bios needed
    Re: Dell Latitude E6540 bios nedded
    Unfortunately, it does not work, it does not pass POST SEQUENCE, LED lights up and goes out.
      If you program back your Original Bios the device works or not?
      all donations are welcome,
        Works fine
          Works fine
          This is a New Bios, try it.
          Service Tag: 847GR72.
            I'll test better tomorrow, but now it's running 40 minutes without shutting down, thanks for your help. Can you tell me what you changed in my bios to fix this problem. Please inquire via PM. Regards
              So the file in Post #24 works fine?
                Exactly, I'll test it more later
                  Re: Dell Latitude E6540 LA-9411P
                  Originally posted by peste View Post
                  try...
                    Do you have by any chance LA-9414P working BIOS for both chips? Black screen, fan is spinning and CPU is hot. No external or internal screen works, no error sound. Only error sequence on power LEDs when there is no RAM inserted.
                      Read the rules before posting:
                      Become a Badcaps supporter
                      Thanks to all supporters.
                        Dell e6540 vala1 - corupted bios ?
                        Good morning. I have a Dell e6540 vala1 la-9412P. The laptop turned on with a black screen. After resetting, the bios turns on for a few seconds and then turns off. Would any kind soul take a look at the bios/ec files? I tried various solutions from the forum but without any positive results
                          Re: Dell e6540 vala1 - corupted bios ?
                          You MUST:
                            Sorry, fixing my last incomplete post.
                            Laptop model: Dell Latitude E6540 with i5-4310M, no dedicated GPU
                            Motherboard model: LA-9414P Rev1.0(A00)
                            Service tag: 9824S32
                            Dump of both 64 and 32 chips is in the attachment.
                            Problem is no video output, not in built in display nor in external through VGA / DP. Only black screen. Fan is working. Keyboard backlight is working.
                            On the sidenote, I tried reflashing some bioses that I found online for this specific board, but boot time is 25 seconds until Dell logo and 45 seconds until Dell logo if secure boot is enabled. For both uefi/legacy. Also sleep is not working and will restart computer instead. But laptop works fine overall, wont shutdown, tested for few hours, so it's at least usable. I even tried updating official BIOS update from Dell website through their .exe file, but it doesn't have any effect and laptop just restarts.
                            So I would be glad if the BIOS I had before is fixable, but I will make my peace if its not and use the one I found.
                              Just to update on my issue, I no longer need help. I used and flashed BIOS from post #24 and although it was for another motherboard model, it worked flawlessly and everything is fixed, its fast, sleep works and its also newest BIOS version as a bonus. Big thanks hardware1!
                                Hello Guys & Gals ! I Need help with this Dell Latitude E6540 Bios, Laptop is no power, i've tried to reprogram to a multitude of other Bios Files, but it either gets no Post or Infinite fan spin of death....
                                So I was hoping one of you kind Gentlemen/Gentlewomen could help me out in this case ?
                                it's a Dell Latitude E6540
                                With a VALA1 LA-9412P Rev:1.0(A00) Motherboard of 2014-04-11 Build year i guess ?
                                It's S/N or Tag.... sorry can't find any on the cover or anywhere for that matter !
                                Anyhow big thanks in advance !
                                  Latitude E6540
                                  Service Tag: 5B58N12
                                    Originally posted by hoaca388 View Post
                                    Latitude E6540
                                    Appreciate the help man but it did not work sadly
                                      thank you
                                        See if it works...
